Old 07-18-2013, 08:42 PM   #1
1976 27' Overlander
Gray , Tennessee
need 76 overlander wiring diagram
I am having trouble with finding a wiring diagram for my 1976 overlander. It's a 27' double with the back end bathroom. Looks like someone has added an extra service panel for some strange reason. trying to put it back to the way it should be. Does anyone know where to find this schematic?
izzyashdown is offline   Reply With Quote
Old 07-19-2013, 09:48 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings izzyashdown!
Welcome to the Forums and the world of Vintage Airstreams!
You may have a situation where a prior owner has replaced the original Univolt power converter with a more modern unit. Many of the newer RV power converters do not have built-in fuse panels like the original Univolt so part of the upgrade to a newer power converter involves installing a new 12-volt DC fuse or circuit breaker panel.
You may find it beneficial to have the owners' manual and repair manual for your coach, and these may be obtained from Airstream:Good luck with your investigation!
Kevin
P.S.: If the original Univolt has been replaced, that is generally a good thing as these OEM converters have a reputation for boiling the battery electrolyte resulting in shortened battery life.
Kevin D. Allen
AIR #827
Old 08-09-2013, 06:01 PM   #3
1976 27' Overlander
Gray , Tennessee
strangely enuough airstream manuals skip1976 on their website. I was hoping someone would have one they could share??? maybe not
