No separate converter. The Magnum inverter is also a converter/charger.
Check out technomadia.com and gonewiththewynns.com for solar/inverter systems sized around what you're asking for.
You should be able to fit around 600w of flexible solar on your roof. If you need more than that, you'll probably need a ground deploy.
I would suggest installing a combiner box on the roof and the shortest possible run of Big Whopping Wires from the box to where you will be putting your solar charge controller and inverter. Then proceed with your renovation. If you don't already have a working converter, you might want to buy the Magnum and a small battery now so that you can run your
12v system.
Pre-wiring for solar now will make it easy to put whatever panels you need on the roof later. You can see how we did it on the blog in my signature. You'll be able to live with the coach connected to shore power for a while to observe your actual usage and determine how much power you really need. Otherwise you're going to end up over- or under-buying a bunch of really expensive stuff.
