Old 06-20-2019, 08:30 PM   #1
1988 34' Limited
Bainbridge , New York
Mystery Yellow Wire Running Along LP Line
I am disconnecting the propane so we can paint the tongue and get it cleaned up. I found that there is a yellow wire at the tongue that connects to a small metal plate with two screw holes. The plate is not connected to anything and is just dangling. The wire runs from the tongue and then along LP line under the AS. Can anyone identify what this mystery wire is for? I couldn't find it in the wiring diagrams.
mystereons41 is offline   Reply With Quote
Old 06-20-2019, 08:49 PM   #2
dznf0g's Avatar
Oswego , Illinois
Inside lp tank gauge? I think, traditionally, one is yellow and one is red.
-Rich-
Old 06-20-2019, 09:19 PM   #3
1988 34' Limited
To be honest I am not too familiar with gas systems, and we just got the AS so I'm still trying to figure out what is what. There is a wire attached to each of the propane tanks, I assume they are for the fuel level gauge? I am not sure if the yellow wire is a part of the gauge system or something separate. The plate is not attached to anything, and only the yellow wire is attached to the plate. I posted a pic in the first post that shows the metal plate and the wire.
Old 06-22-2019, 07:21 PM   #4
1988 34' Limited
Here is a close up of the plate with the yellow wire. In the background is the disconnected propane line under the tongue. The wire runs along the propane line. Any ideas what this wire is for?
Old 06-22-2019, 08:46 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Probably yes. the propane guage is not reliable anyway. I don't worry about mine.
Yellow and white wire Phadreas Brakes & Brake Controllers 0 10-26-2016 12:15 AM
Weight distribution brackets and the Propane gas line along the Otterbrawten Towing, Tow Vehicles & Hitches 16 05-11-2016 11:37 AM
yellow wire in right rear light assembly. robertel Lights - Interior & Exterior 6 09-18-2010 06:14 AM
Taillight wiring, where does yellow wire go bmklawt Lights - Interior & Exterior 3 03-17-2009 05:20 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
