Old 02-26-2012, 02:15 PM   #1
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
Mystery wires
So on my '92 Excella 29' I have two wires that exit the floor of the trailer under the a-frame and just hang. I have tested them and can not find any current or continuity. They are yellow and red. They yellow wire is marked as resistant to oil and fuel? I decided to pull the front interior panel to see where they went. Thea attach to two other wires Yellow to Light blue with white stripe and the red to Dark blue with red stripe. See the photos.
Also have a larger gauge pink wire that is bundled with no terminal end just behind the univolt. In looking behind the inner panel it looks like this wire was not in the original bundle (as seen in the photo)
Any ideas or suggestions as to where these wires may run would be helpful. I guess as long as things are working I just leave them alone, I do wonder what should be working that I just have not discovered yet.
Thanks to all who have done complete restorations and may have the answers.
Jon
ID:	152035   Click image for larger version
ID:	152037   Click image for larger version
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Chillpoints is offline   Reply With Quote
Old 02-26-2012, 02:16 PM   #2
1992 29' Excella
Thought I would share a picture of the schematic that I have. It has been no help to me but to someone else perhaps.
Thanks again.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 02-26-2012, 02:47 PM   #3
1974 Argosy 20
Kooskia , Idaho
This is a wild guess, but do you have a break away switch on your trailer? If not, could those wires have gone to it (now missing).
Old 02-26-2012, 03:02 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Jon,
Check the wires inside that the mystery wires are attached to for power. Check against each other and against the frame in case one of the mystery wires is not a ground. Then trace the wires the mystery wires are attached to back to their source until you find them. There may be a dead fuse, or they may end somewhere and not be attached to anything.
It is possible the previous owner used them for some reason temporarily, fixed whatever it was, and left them there in case he needed them. Or maybe he had something extra attached to them and kept it when he sold the vehicle.
Gene
Old 02-26-2012, 03:11 PM   #5
1992 29' Excella
Thanks for the suggestions.
I do have working breakaway switch and can trace the wires from that fine.
I have checked and do not find any power or continuity between the wires or with either and a common ground. The wire connectors as seen in the picture appear to be original, not aftermarket.
I was trying to see where they lead but do not want to pull all the interior skins to trace them. Not doing that kind of renovation. The heavy pink wire is the same type and style wire that is in the bundle and connects to the fuse box. Was wondering if this could be a sleeper wire for future solar. But where does it go is the question. Keep the suggestions coming. Surely someone knows the color scheme for this thing
Jon
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 02-26-2012, 03:11 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Do you have a battery in the trailer? If not you may not see a voltage reading on these wires. Is there a break away switch mounted on the tongue? Is there an electric tongue jack? Perhaps there was and it has been removed.
Old 02-26-2012, 03:15 PM   #7
1992 29' Excella
Yep battery is installed and all things that I know of work. Power jack is connected by heavier wire that is gray.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 02-26-2012, 04:15 PM   #8
2005 30' Classic
Images: 12
Might be for your axle brakes... If while hooked up (electrical wise) to the TV, you have someone press the brakes, is one color of wire hot?
GetOutDoors is offline   Reply With Quote
Old 02-26-2012, 06:43 PM   #9
Master of Universe
Gene's Avatar
Forum blip made my post disappear. Bummer.
Those wires are too small to be solar wires.
Look under trailer and you'll see wires coming from each brake assembly in the back. Front and rear axles are connected to each other and wires that go to the umbilical. Have someone step on the brake pedal and listen for the hum of the magnets at each wheel.
I had some brake work done at JC and some miles later found brake wires hanging down and disconnected.
Gene
Old 02-26-2012, 06:48 PM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Mystery wires
Just a thought, is it possible that the original owner might have had the dealer install the Tele-Tec flat detection system, and the refrigerator cut-off switch that was offered in the 1985-1988 Airstreams?
Kevin
Kevin D. Allen
AIR #827
Old 02-27-2012, 04:59 AM   #11
1992 29' Excella
Breaks work fine. I can trace these wires from the plug to TV. Have not heard about the leak detection option nor the fridg shut off. Just had the refrigerator out and there were only two wires (much heavier) a maroon hot and a white common.
Were there other options that could be possible? Was wondering if I could call the mothership or better yet if Andy at inland has experienced this.
Thanks for any suggestions.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 02-27-2012, 07:34 AM   #12
1992 29' Excella
Does anyone have a complete color scheme for the wiring in the '92 trailers? I have been trying to use the one in the manual and can not decipher all the color combinations. It looks from the print version (posted above) that the colors are simple one color for the most part. Many of these wires are two color. Any electricians who can help with a code key?
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 02-27-2012, 07:48 AM   #13
1988 25' Excella
Trumbull , Connecticut
Hello All. On my 1988 Excella which had the original 9 pin connector, the 2 extra wires was for the refer cutoff and the flat detector and on my 88 neither were connected.
Good luck and happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 02-27-2012, 12:19 PM   #14
1992 29' Excella
Flat Detector?
nm1oqrz
Thanks, I am curious if you know anymore about the flat detector. Where might the other ends of the wire be, and how did it work. I have not seen or heard of this feature before. Any help would be appreciated. Short of pulling down the interior skins and tracing the bundle of wires along the ridge of the trailer, I am at a loss as to where they may go.
Also do you know what the purpose of the refer cut of was? Mine has a switch on the top of the fridge for on/off but not a remote switch.
Thanks for sparking my curiosity and any potential answers.
Jon
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
six wires in furnace location...what to do? pablobagus Electrical - Systems, Generators, Batteries & Solar 9 02-24-2012 07:17 PM
Wiring new Suburban furnace too many wires?? pablobagus Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-23-2012 08:44 PM
Mystery Water in Bedroom Carpet KrazyKelleys General Repair Forum 4 02-09-2012 06:41 PM
What are these wires for? -Interior of '72 Safari 23ft. Foxbrook Lights - Interior & Exterior 13 02-06-2012 01:27 PM
Bare wires above water pump??Interstate 3500 2012 TY PECK Electrical - Systems, Generators, Batteries & Solar 2 01-23-2012 03:15 PM
