Old 11-25-2006, 06:52 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Question mystery part on 71 Trade Wind
I have begun restoring this 71 Trade Wind. There is a small 5/8" x 1 1/14" barrel shaped thingy mounted to the front curbside of the trailer about 6 inches below the window. It has a knurled side and says Chicago and some other stuff I can't read on the square mounting flange. On the inside of the coach there is a heavy guage 3 strand piece of insulated wire with white insulation also covered by a black sheath. At the inside end of the wire is a circular end to attach it to some other thingy. I don't know what it is, if it is aftermarket or what it attaches to. The only thing I can think of is it may be an aftermarket outside temperature sensor, but why the heavy electrical wire. If it is not original it obviously has been there for some time. I would appreciate any ideas anyone out there may have.
Marshall
Old 11-25-2006, 07:04 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Marshall
Some sort of antenna mount, perhaps?
Uwe
www.area63productions.com
Old 11-25-2006, 07:10 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
antenna mount
There is a factory radio antenna in the usual place on the front roadside corner. If it is an antenna mount maybe for an old CB is a possibility.
Old 11-25-2006, 07:35 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Photo of "mystery part"
Here are some photos. One is from the outside. The part is about 6 inches under the curbside corner of the front window. The other phot shows the cable and where it enters the coach under the front window. If you don't get the attachments I can email the photos to you.
Marshall
ID:	29014   Click image for larger version
Old 11-26-2006, 04:17 AM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Coaxial wire, like the stuff in your picture, is typically used for antennae. Kind of odd that the wire has no fitting on the inside end of it.
The outside fitting is about the size of a CB radio fitting.
Hopefully a Ham Radio enthusiast will catch this thread. Member Airstream25 might have some insight.
Tom
Old 11-26-2006, 06:20 AM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Perhaps it was for a television cable, and was run through the fitting rather than under the door, or through a window.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 11-26-2006, 06:45 AM   #7
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I would definitely say it was added since the plate is held on with screws and not rivets. My concern is that it would be a good place for water to enter the trailer particularly when you are travelling down a wet road. You could remove it and place a small patch over the hole, caulk the patch well and give it a name so you will not mind that it is there.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-26-2006, 06:53 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Kind of hard to judge the size of it, but it looks to me like a cable television fitting.
Aaron
WBCCI #XXXX AIR #2495
Old 11-26-2006, 07:02 AM   #9
1976 25' Caravanner
Campton , New Hampshire
There looks to be some writting on the wire , what does it say ? It may tell you what it is.
ticki2 is offline   Reply With Quote
Old 11-26-2006, 09:58 AM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
Yes it is coaxial but about twice the thickness of TV coax. It says Vikoa 6100 RG8U Type Low Loss. There is no place to screw into on the fitting like a TV coaxial connection.
Old 11-26-2006, 10:17 AM   #11
TomW's Avatar
1967 26' Overlander
Marine Single Side Band (SSB) radio, also referred to as HF radio, uses that type of coax. It is called HF, or High Frequency, because of the frequency range used: 3 to 30 megahertz.
Does your Airstream look like it has been in water?
Tom
Old 11-26-2006, 11:20 AM   #12
Lumatic's Avatar
1993 34' Excella
Images: 16
Sooo, either I get a ham radio, although it has been said in some circles I am, an outboard, or take the rascal out?
Marshall
Old 11-26-2006, 11:51 AM   #13
TomW's Avatar
1967 26' Overlander
If you take it out, you will need to cover the hole.
It should be a PL-259 bulkhead fitting:
You could replace it, and then cap it for aesthetics:
Tom
Old 11-26-2006, 01:28 PM   #14
1976 25' Caravanner
Change it out for a TV coax , it will fill the hole and you can use it .
'59 Trade Wind flyfshr 1959-69 Tradewind 196 03-10-2013 09:42 PM
Manual for '72 Trade Wind igor 1970-79 Tradewind 10 05-04-2005 09:55 PM
Trade Wind Eyebrow Windows uwe 1970-79 Tradewind 6 07-17-2002 09:10 PM
'72 Trade Wind Pigtail Schematic igor Brakes & Brake Controllers 3 07-14-2002 03:15 AM
repair 1978 Tradewind Pam1 General Repair Forum 1 06-21-2002 08:28 PM
