Old 12-26-2008, 06:43 PM   #1
weiss1957's Avatar
1970 18' Caravel
San Jose , California
Images: 11
My Trailer Trips the GFCI Circuit - Help?
Last night when I went to show off our new 1970 Airstream Caravel to some family members that were over for Christmas I had an unexpected surprise. I walked out barefoot on wet concrete and when I went to open the door I got shocked. I unplugged the shore power and then it was no problem. Today I tried to find the problem by using a circuit tester and found that I had an open ground on the AC plug I was using. When I tried another GFCI circuit it tripped.
I can still plug the AS into a grounded kitchen outlet (non GFCI) and it works fine, but I am reading about 2 VAC from the skin of the trailer to earth (ground).
Any ideas of where to start troubleshooting? I can read a meter and turn a wrench, but I am a bit puzzled. Any help would be appreciated.
Mike
weiss1957 is offline   Reply With Quote
Old 12-26-2008, 08:13 PM   #2
Mike
Go to Home Depot and pickup a "polarity tester."
The source of power to your trailer is incorrectly polarized, or the trailer is mis-wired.
Start your tests at the source of power.
Old 12-26-2008, 08:18 PM   #3
HeadnOut's Avatar
Ruther Glen , Virginia
Not sure I ca help, but I have a few Questions.
...for your shore power, what kind of power cord ar you using?
...was the cord laying in the water and could it have a short or a bad spot on the cord?
...is your electrical ground wire connected to the trailer properly?
just a few thoughts to start with.
Headn'Out
HeadnOut is offline   Reply With Quote
Old 12-26-2008, 11:43 PM   #4
MT. Vernon , Washington
I agree with Head'nOut, grounds are often the cause of GFI problems and "shocks". Check your 110 electrical box and the chassis ground. The other thought I had was a frayed shore power cord or has it been "yanked" a good one by a PO? Check the junction box and connections there. Let us know...VK
vikx is offline   Reply With Quote
Old 12-27-2008, 12:32 AM   #5
Ifihadtime's Avatar
1981 27' Excella II
Lynnwood , Washington
Along with everything else said, turn off all the breakers in the trailer and check for the leak. If you don't find one flip on one breaker at a time to see which circuit has the leak. Hope this helps, let us know what you find.
Ron
81 Excella II
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 12-27-2008, 12:47 AM   #6
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
If your get shocked... then I would think that the wires coatings somewhere have rubbed off and is connected to the aluminum frame somewhere... water could also be making the connection. I agree with Andy and start testing all the different areas and find out where your system has gone wrong!
Vin...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-27-2008, 08:58 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you do not find the problem to be polarity at the source remove the electrical power panel cover and check polarity of the shore cord, with all breakers off, as it enters the panel. If these check out OK connect your voltmeter between the trailer and a GOOD GROUND, back at the house, and start turning on each breaker one at a time to isolate which circuit is giving the problem. Once the circuit is located remove items that may be plugged int that circuit one at a time. Don't forget the refrigerator, converter, and the door bell.
Keep this in mind. Even if you find and remove the voltage problem you may still have a problem when plugging into a GFI. This is because GFIs sense ground current and some electrical items, those that have a transformer on the input, may have a capacitor across the line before the transformer. The charging current of the capacitor is enough to trip a GFI. The only way around this is to get rid of the GFI or the electrical item. This tripping does not pose a hazard just a nuisence.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 12-27-2008, 09:07 AM   #8
weiss1957's Avatar
1970 18' Caravel
Images: 11
Some good ideas. Here is my plan for today. Properly ground the GFCI outlet that has a floating ground, then try to find if I have a 120 VAC short to the trailer somewhere.
I was plugged into my garage (the GFCI outlet with the floating ground) when I got shocked. After that I tried to plug into a properly grounded GFCI (same garage different circuit) and it tripped the GFCI. I finally went into the house and plugged into a kitchen (non GFCI) properly grounded circuit. I didn't get shocked in this configuration, but by then it had quit raining and Darwin had taught me that I ought to be wearing shoes...
Shore power was connected with a brand new 15A extension cord adapted to my brand new 30A/15A pigtail from Campingworld. I will say that the old (1970's) 30A cord looks pretty old, but I am sure it was up out of the water when I got shocked. I may replace it anyway as it looks like something that might try to kill you.
So... where do I find the breakers in my trailer ( I just brought this 1970 Caravel home) I looked all around yesterday and didn't see any.
Mike
Old 12-27-2008, 09:14 AM   #9
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Cheap Safety Item
I keep a polarity checker plugged into the receptacle by my stove, I used a marker to color it from yellow to silver to match the aluminum. Now no matter where I camp when I plug the unit in I know the status of my power. Cheap safety check.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 12-27-2008, 09:31 AM   #10
weiss1957's Avatar
1970 18' Caravel
Images: 11
Does anyone know where the electrical power box is on a 1970 Caravel? I thought I saw one somewhere in that thing, but looked all over yesterday and didn't find it.
As for the polarity tester... I am sold. I will henceforth wear one around my neck on a string and test all circuits high and low. I will keep one in my trailer, my bathroom, and my shaving kit for when I go on travel to an unknown hotel...
Mike
Old 12-27-2008, 10:55 AM   #11
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Our 69 breaker box is directly over the water heater in a cabinet in the bathroom. Not sure with yours being shorter and one year newer if its the same but worth checking.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-27-2008, 07:15 PM   #12
weiss1957's Avatar
1970 18' Caravel
Images: 11
I found the breaker box located in the tall closet next to the head. It was behind a thin wooden wall. There was a hole cut so you could switch the breakers, but I needed the cover off.
I spent all day rewiring my garage to make sure that I had that freshly grounded feeling, installed an 8 foot ground rod and tied my GFCI's to that. While I was at it I added a receptacle nearer the trailer and one on the outside wall as well.
With all that fine electrical work out of the way I switched off all my AC breakers in the AS and plugged the trailer in. GFCI tripped in about one second. Hmmm... perhaps the old 30A cord is frayed or is grounding prior to getting to the breaker box. I guess tomorrow I will try some continuity testing to see if that solves the mystery.
I am attaching a pic of my wiring diagram in case anyone wants to ponder it a bit. Any other suggestions/great ideas would be welcomed.
Mike
Name:	1970 Caravel Wiring Diagram Small.jpg
Old 12-27-2008, 08:47 PM   #13
HowieE's Avatar
Images: 12
The next thing I would do is remove both legs of the shore line from the terminals in the box and float them in open air. Then plug the shore line in. If it blows then the cord has water in it.
2004 Excursion 4x4
Old 12-27-2008, 09:19 PM   #14
1989 34' Limited
southern , ontario
First a FLOATING GROUND IS THE POTENTIAL DIFFERENCE BETWEEN 2 GROUND POINTS this is due to poor grounding design along with improper electrical phasing.
Next a correctly grounded trailer is designed to protect you from INTERNAL GROUNDS WITHIN THE TRAILER ( electrical wiring or electrical devices ) BUT and I say BUT again no amount of protection built into the trailer is going to protect anyone standing in water and touching an electrical apparatus of metal.
third you have a high resistance ground not a short circuit. The high resistance ground can be sourced from 120vac appliances or 12vdc , 12vac equipement. be aware that to obtain 12 volts you can use auto transformers or wire wound resistors that have voltage taps, any problems with these 2 items can also creat voltage leaks, and open neutrals can create wierd voltages and back feeds.
safe rving
letsgo is offline   Reply With Quote
Gen. GFCI tripping Cochese Generators & Solar Power 1 08-13-2008 05:54 PM
gfci help oakie Lights - Interior & Exterior 2 06-07-2007 08:50 PM
Gfci achip Electrical - Systems, Generators, Batteries & Solar 4 07-22-2006 11:52 AM
Gfci jcf48 Electrical - Systems, Generators, Batteries & Solar 0 07-21-2006 11:00 AM
First Trips COLORADO_CAMPER 1997 - 2004 Bambi 5 07-18-2003 11:42 AM
