06-15-2019, 01:10 PM
#181
Hagerstown
, Maryland
FYI here’s something I wrote about GFCI theory which includes some simple diagrams. They’re really very simple once you understand the basics of operation. https://www.rvtravel.com/rv-electric...g-gfci-part-i/
06-15-2019, 07:01 PM
#182
2019 30' Classic
Canfield
, Ohio
I don’t have all the details yet, but another Airstream has burned. Seems as if it was in storage and caught on fire. Completely melted.
Sorry for highjacking my own thread, but can this be electrical?
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
06-16-2019, 06:51 AM
#183
Sag Harbor
, New York
No sign of that fire in an online search. Do you know the location?
Peter
PS -- No recent updates on that Fire thread FWIW:
http://www.airforums.com/forums/f543/fire-190179.html
06-16-2019, 07:00 AM
#184
2019 30' Classic
Canfield
, Ohio
Originally Posted by OTRA15
Tod Endl (Arkansaw) from Airstream addicts posted the pictures. It is his trailer. I don't know the year or model. I am not on Facebag but my wife caught this last night.
I don't know if it is OK to post his pictures here so I won't.
Edit: 2005 international and he had problems with refrigerator not cooling.
Tom & Doty
06-16-2019, 07:12 AM
#185
Sag Harbor
, New York
Thanks.
Wow!
https://www.facebook.com/groups/AirstreamAddicts/
Posted at about 8 PM last night +/-. Over 300 comments. I am not a member of Fa[r]ceBook, so I won't dig any deeper, however his posting appears to be viewable by non-members. Maybe a malfunction of the fridge propane valve?
Thanks again,
Peter
06-16-2019, 09:23 AM
#186
Hagerstown
, Maryland
I’m going to investigate this further on my RV Electricity Group and will repost anything I find out on this forum as well. Here is my group: https://m.facebook.com/groups/2605407496153410?view=permalink&id=273862225949859 9&comment_id=2738936816133810¬if_t=group_commen t¬if_id=1560690689435658&ref=m_notif
06-16-2019, 10:31 AM
#187
Hagerstown
, Maryland
Thanks.
Wow!
Thanks again,
Peter
I’ve made contact with the AS owner and will post anything I’m allowed to here.
06-16-2019, 12:47 PM
#188
Sag Harbor
, New York
Thanks. Looking forward to updates. BTW your link in the earlier post is NG.
Peter
06-16-2019, 01:02 PM
#189
Hagerstown
, Maryland
Peter
Oops... Here's the link to my RV Electricity group on Facebook: https://www.facebook.com/groups/rvelectricity
06-17-2019, 06:11 AM
#190
2019 30' Classic
Belleville
Do surge protectors typically also offer ground fault protection?
06-17-2019, 04:21 PM
#191
Hagerstown
, Maryland
I’m not sure I understand the question but perhaps you could start a new thread and I’ll try to answer your surge protector questions there.
06-18-2019, 11:48 AM
#192
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
No, at least not in the sense that a ground fault outlet does. They do normally check for an "open neutral" condition which is not normally called a ground fault.
06-19-2019, 07:30 AM
#193
2018 27' Globetrotter
Mooresville
, North Carolina
WBCCI Int’l Rally Using Electric Daisy Chain?
I was reading the June, 2019 Blue Beret. Page 39 / Rally reminder #22 states that the 30 Amp service provided will be (electric daisy chain).
Am I reading this correctly? If so, it would appear the same situation could occur that happened at Alumapalooza. Hopefully, someone more knowledgeable than I can weigh in on the electric situation at the event. Item #21 also state they want to avoid overloading the temporary power grid.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
06-19-2019, 07:42 AM
#194
Mantua
, Ohio
Follow the rules and all is fine.
06-19-2019, 07:59 AM
#195
2019 30' Classic
Canfield
, Ohio
We all followed the rules when we arrived. The wiring was wired wrong. Should they have followed the rules and had the wiring inspected as most community government would require? Would you like me to hire an electrician to check the wiring before we plugged in?
I will follow the rules next year as I will be in the generator group. I can control my environment there unless I still need to figure out if I need to bond my generator!
Tom & Doty
06-19-2019, 08:05 AM
#196
2012 25' FB International
Trent Woods
, North Carolina
We have been to a large region 3 rally at Doswell and everything was done right, very professional. Can't say whether it will be done the same way for this bigger rally.
Larry
06-19-2019, 09:21 AM
#197
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Everyone will have dedicated 30A connections, so this is not the 3A daisy chain experienced at Alumapalooza. I believe they are asking for fridges and water heaters to be on propane to make sure there is enough power for 700+ air conditioners. I assume the "daisy chain" comment suggests some 30A extension cords may be used, but that is a guess since I am not involved with the electrical committee.
Joe
WBCCI/VAC #702 & #6768
