Old 06-10-2019, 07:03 AM   #141
Long Island , New York
Originally Posted by xrvr View Post
Six pages making a mountain out of a mole hill.
SOP.
“ . . . Talk first, think later . . . “
Old 06-10-2019, 07:10 AM   #142
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Originally Posted by ROBERT CROSS View Post
Better than a pile of melted AU...🥴
AU is gold and it should be for the price. I hope you meant AL
Larry
lsbrodsky is offline   Reply With Quote
Old 06-10-2019, 07:10 AM   #143
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
No one is born knowing everything (though I’ve met some folks who believe they were....). Hashing out a discussion to learn something shouldn’t be problematic. It’s something I love about the forums. I’m still trying to make up my own mind about this and appreciate everyone’s input....
If there is a risk of danger (mountain) that a simple device in these specific circumstances can alleviate - that’s a good thing. If it offers no protection from the issue and serves only to trick an EMS - then yeah - it’s a molehill. I’m still listening and learning - sorry if that’s ticking people off. If you know what you need to know - share it or just avoid the discussion altogether. Makes for a happier life
SteveSueMac is online now   Reply With Quote
Old 06-10-2019, 07:30 AM   #144
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
ID:	342944 I have been following along and think I am starting to understand most of what is being said. Maybe. My question is with a Honda Industrial EB2000i, which has a GFI and is “ neutral bonded to the frame” , is it okay to plug into the Airstream without the bonding plug? If I understand correctly, it should be okay. When I test the generator with the plug-in device,which comes with an Airstream, I get the “correct” indication with the lights. I do have a 50 Amp EMS but I don’t use it with the generator mostly because of the size of the EMS an number of adapters I would have to use. Comments?
JDG is offline   Reply With Quote
Old 06-10-2019, 02:26 PM   #145
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Larry
$$$$$=AS+AL=AU🤔
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 06-10-2019, 05:03 PM   #146
2019 30' Classic
Belen , New Mexico
Originally Posted by JDG View Post
Attachment 342944 I have been following along and think I am starting to understand most of what is being said. Maybe. My question is with a Honda Industrial EB2000i, which has a GFI and is “ neutral bonded to the frame” , is it okay to plug into the Airstream without the bonding plug? If I understand correctly, it should be okay. When I test the generator with the plug-in device,which comes with an Airstream, I get the “correct” indication with the lights. I do have a 50 Amp EMS but I don’t use it with the generator mostly because of the size of the EMS an number of adapters I would have to use. Comments?
Yes. That generator needs no bonding plug. The bond is built in (hence the working GFCI plug on it.)
Ephraim is offline   Reply With Quote
Old 06-10-2019, 08:21 PM   #147
2019 22' Sport
San Antonio , Texas
Terrible and scary. I’m so sorry. Hope it is resolved soon.
Doc10r is offline   Reply With Quote
Old 06-11-2019, 04:32 AM   #148
Hagerstown , Maryland
Everyone. Yup, It's Mike Sokol from RVelectricity and the No~Shock~Zone again. Would any of you happen to have pictures of how the power at Alumapalooza was run? I'm especially curious to see how the 20-amp circuit was split to multiple RV's as noted in the very first thread on this post. Thanks....
You can post them here or email mike (at) noshockzone (dot) org. Mike Sokol
jmsokol is offline   Reply With Quote
Old 06-11-2019, 05:05 AM   #149
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I don't have any specific pictures, but I believe I know how it was run. They had a main breaker box with many 20 amp breakers. They ran white electrical wire on the ground to a pole holding 2 dual-plug electrical receptacles in a metal box. That provided four trailers with a 20 amp circuit. There were 42 trailers in the field, but at least 10-12 were in the generator section with no power. 30 trailers hooked to the electrical system. I was told it was a 20 amp circuit but I can not verify this. We were told we had 3 amps to use. The host said it was a 20 amp circuit. They threw a 5-gallon bucket over the plugs to keep them dry.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
xxx Council Rejected! xxx
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 06-12-2019, 02:39 AM   #150
When you say "white electrical wire" do you mean some kind of solid conductor Romex wire like you would run inside the walls of your house or RV?
Old 06-12-2019, 06:54 PM   #151
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
yes, romeo.
Old 06-12-2019, 06:57 PM   #152
2007 27' Safari FB SE
Forest Grove , Oregon
Would it be a mole hill if it was your trailer that had components fried, and an electrified skin?
bweybright is offline   Reply With Quote
Old 06-13-2019, 04:15 AM   #153
I agree. This appears to be a pretty serious code violation. I’m investigating it further.
Old 06-13-2019, 04:27 AM   #154
Gainesville , Florida
Yes.it was a problem, it was solved, it now has devolved into a generator grounding thread.
« trojan T 105 price | Top | - »
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DougFelts
No power to trailer from shore or batteries. Converter fried? MarkHB Batteries, Univolts, Converters & Inverters 7 07-09-2017 04:47 PM
Fried hot water heater diode jimlegs 2006 Safari SE 12 09-09-2012 10:36 AM
Fried trailer wires Monicaro Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 04:08 PM
Breaker for running lights got fried dickmfield Lights - Interior & Exterior 2 05-06-2010 02:05 PM
Power hitch jack - fried? Toasty's Dad Hitches, Couplers & Balls 9 02-06-2006 10:26 AM
