Old 06-09-2019, 12:23 PM   #127
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You are welcome! The simple fact is your EMS will not allow current flow from a generator unless you use one of these. Folks can debate the need/safety forever, it seems.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-09-2019, 12:59 PM   #128
Hagerstown , Maryland
I'm Mike Sokol from RVtravel, RVelectricity and the No~Shock~Zone. I also invented t he Neutral-Ground bonding plug referred to above, as well as taught a number of seminars on portable generator bonding and grounding principals. If I could get any support from Airstream I would love to create some Airstream specific articles and videos on AC hookup and grounding, as well as present seminars about it at some of your rallies. Please have anyone interested contact me at mike @ rvtravel (dot) com to discuss.
jmsokol is offline   Reply With Quote
Old 06-09-2019, 01:03 PM   #129
Winemaker
rgwatkin's Avatar
2012 28' Flying Cloud
Avila Beach , California
I would be asking AS for a new trailer. Who knows what other damage it did under the skin. The least they could do is give you a loaner until yours is fixed.
rgwatkin is offline   Reply With Quote
Old 06-09-2019, 01:20 PM   #130
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Knock knock
Folks Mike Sokol is reaching out.
Have you watched his hot skin and bonding plug and other RV electrical training videos?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-09-2019, 02:14 PM   #131
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I had my 1000w Magnum inverter in my Interstate fried at Alumapalooza last year. I was not using my surge suppressor. First clue, after I left, was my batteries not getting charged. When I opened up the old inverter, one of the PC boards had been fried. Cost me about $700 to replace.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 06-09-2019, 02:45 PM   #132
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I donít know why AS needs to give permission Mike - I think if youíre a vendor a selling a product you can declare that in the forums somehow - thatís all good. Iíd be glad to check out your videos and info.
Ephraim above answered my question - it seems to make more sense to my untrained mind. Iíll dig deeper but I think unless you need to declare some vendor relationship, you should feel free to post your thoughts. Love to hear them!
Old 06-09-2019, 03:13 PM   #133
Long Island , New York
Originally Posted by Pahaska View Post
. . . I was not using my surge suppressor.
Old 06-09-2019, 03:27 PM   #134
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by SteveSueMac View Post
Iím not sure if this question will help resolve this or not.
It seems the two camps as it were are:
A) the bonding plug is a safety device
B) the bonding plug is a device to trick a ground fault detector
While I suppose both could be true, my personal confusion is that if A is true, the plugs identified for this purpose look so small, itís hard to imagine them providing any safety - in my electricity-untrained mind, Iím envisioning the ďsafetyĒ of an 8í rod driven in to the ground to discharge a wayward voltage vs. a 3-prong plug with at best a 10G wire.
While I can clearly see how the device can trick a sensor, I canít see how it provides safety. Can that be explained to an untrained person like me?
Now that assessment and question alone likely demonstrates my complete ignorance on the matter, but for me anyway, thatís why the issue isnít settling.
If that helps focus anything - great. If it only further muddies the waters, just ignore it.
Thanks!
Hi
Take a look at the size of the wire in your power panel. None of it is very large. A perfectly fine piece of wire will fit in one of those little plugs. It does not take a giant cable to get this done.
Again, none of this has anything to do with connecting to planet earth. You are simply tying two wires together the way they *should* be tied together. That's it. No downside, no risk from doing it, near zero cost.
Old 06-09-2019, 06:25 PM   #135
2019 Nest
Omaha , Nebraska
That is super scary! Being newbies, we loved all the information the different speakers gave us at our first Alumapalooza this year. We already had a good surge protector, but did not know about shutting off circuit breakers, testing electrical at power box with the surge protector BEFORE plugging in our trailer. Well, turns out that was very valuable information, since we camped on our way home from Alumapalooza, and the last campground we stopped at was one near our home that I have camped at for 30 years. We pulled in to our site, did the surge protector test, and sure enough, it showed reverse polarity! I went back to the office and told them no way I was plugging my Airstream trailer into that! They reassigned us to a site with good electric and immediately sent a technician to check out the bad electrical site. I'm sure Jackson Center will take care of you, and you can figure out exactly what happened.
2019 Airstream Nest
2018 Chevrolet Silverado 1500
Beboplu is offline   Reply With Quote
Old 06-09-2019, 06:38 PM   #136
Hi
Exactly right. In fact, if you have an on-board generator in your RV the transfer switch performs the function of bonding the neutral and ground together while on generator power, but separating the neutral and ground while on shore power. That's because your RV expects a bonded neutral-ground from the generator OR the shore power line (but never internally). Since a portable generator is connected to the shore power connection without a transfer switch, my simple G-N bonding plug performs this function. Simple, isn't it?
Old 06-09-2019, 07:48 PM   #137
2018 27' Globetrotter
Mooresville , North Carolina
I had posted some questions on this subject and wanted a simple yes or no answer as it pertained to my useage with my Honda EU2000. I was never able to get an answer so I took "JMSOKOL", post #125, up on his offer to assist. Below is his response to me. I hope this helps others who may be in the same situation as myself. Mike Sokol's answers are in BOLD. I appreciated his simple / straightforward response. He approved my being able to post his response to me.
Post #107
Electrical Novice here again.
Based on what I just read, the answers to my questions should be;
With that background, Will I harm my trailer if I,
1. Use a bonding plug, and use my surge protector between the generator and the RV? No, my RV will not be harmed.
Yes, you can use a bonding plug on any Honda or Yamaha Inverter generator, along with any surge protector and it works perfectly. Iím the guy who invented the generator Neutral/Ground bonding plug, so I know how this works. (Mike Sokol)
2. I am assuming by adding the surge protector in this chain will provide me with additional protection than I have had in the past. Is this a valid assumption or just an unnecessary step? Yes, it is a valid assumption in the instance that the generator does not supply correct voltage to the RV.
Is this the correct conclusion? We have 2 views of whether to use a bonding plug on a Honda 2000 or not.
Yes, you can always use the extra protection, so hooking up a surge protector to any generator is a good idea. Iíve never had a Honda or Yamaha fail in high-voltage mode, but Iíve seen this on a number of contractor and Chinese generators. (Mike Sokol)
As mentioned earlier I have not had any issues in the past of not using a bonding plug. I do not want to start using one and find out I created a problem where none existed before. If the above answers are correct, then IMO I donít care which view is correct and I wonít put my RV or myself in any danger / risk by following the above practice.
Mike Sokol / JMS Productions
jmichaelsokol@icloud.com
301-964-5682 (Cell)
301-202-8719 (Fax)
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 06-10-2019, 05:03 AM   #138
Fort Collins , Colorado
glad you are on the right side of the grass
what waninae39 said is very good. Always use surge protection everywhere you go. Even if it isn't a big gathering like Alumapalooza. Park pedestals sometimes are wired incorrectly and park power surges are very common especially in the summertime with over-crowded conditions. Power surges into your coach can wear on your electrical appliances and systems and cost you a lot more $$ in the long run.
Alex12 is offline   Reply With Quote
Old 06-10-2019, 06:37 AM   #139
Gainesville , Florida
Six pages making a mountain out of a mole hill.
Old 06-10-2019, 06:49 AM   #140
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Better than a pile of melted AU...🥴
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
No power to trailer from shore or batteries. Converter fried? MarkHB Batteries, Univolts, Converters & Inverters 7 07-09-2017 04:47 PM
Fried hot water heater diode jimlegs 2006 Safari SE 12 09-09-2012 10:36 AM
Fried trailer wires Monicaro Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 04:08 PM
Breaker for running lights got fried dickmfield Lights - Interior & Exterior 2 05-06-2010 02:05 PM
Power hitch jack - fried? Toasty's Dad Hitches, Couplers & Balls 9 02-06-2006 10:26 AM
