Old 10-21-2011, 06:56 PM   #1
2012 23' FB International
Grayson , Georgia
Unhappy My refridgerator won't turn off!
Hi all. Just brought our 23fb international home last weekend. I went out to get a CD still loaded in the player and noticed that nothing came on; the batteries were dead.
I connected the trailer to ac power in my home and noticed later that the 'fridge came on. I just wanted to power the batteries. So after making certain the 'fridge was in the off position as well as disengaging, so I thought, the breaker, the fridge continues to come on.
Is this normal or am I missing something? Thanks!
politicurl is offline   Reply With Quote
Old 10-21-2011, 07:25 PM   #2
screamstream's Avatar
2012 25' FB Eddie Bauer
Johnson City , Texas
Is the refrig running off of propane? it should shut off then you turn it off?? Just check the propane and turn all that off also. Also the batteries won't charge if you flip that battery disconnect switch, I am told....good luck!
Carol D.
2012 Eddie Bauer 25'
Johnson City, Tx
screamstream is offline   Reply With Quote
Old 10-21-2011, 07:26 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Starting with the basics. There is an on/off switch inside the freezer door, push it once, and the little green LEDs that show the temp should go out.
It's very possible somebody (customer? Dometic or Airstream employee?) got ham-handed, and crushed the film switch. Are you switching the use/store switch off when you're done, and are you unplugging the trailer when you do that?
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 12:26 PM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 08:41 PM
Confusing turn and brake light problem mikeandnora Lights - Interior & Exterior 13 05-29-2011 08:30 AM
LED Sequential Turn Signal moosetags Lights - Interior & Exterior 15 04-09-2011 12:13 AM
How often to turn on water heater? DJW Water Heaters, Filters & Pumps 19 03-16-2011 12:56 AM
