Old 05-12-2010, 12:08 PM   #1
Gator113's Avatar
2007 25' Classic
Port Angeles , Washington
My Honda EU2000i hates me... please help.
I bought a Honda EU2000i generator about 3 years ago to use on my boat. I has very low hours and continues to start on a single pull and seems to be running smoothly. I have never needed to tune it.
We bought our first Airstream this past April Fools Day.
Last weekend I bought a second Honda generator, EU2000i "Companion". We don't need an air conditioner where I live, but when we travel, it's a requirement for my survival (health issues), so I had to spring for the extra grand.
I will now attempt to make a very long (and confusing to me) story a bit shorter.
This is what occurs when using these generators on our trailer.
Front Receptacle:
Connecting the power cord from shore power, there is a 20 second delay before any power in the Airstream. The power then stays on. It is my understanding that THIS delay is normal.
Connecting to our 3 year OLD Honda 2000 generator, has 20 second delay, then power to the entire trailer cycles on and off every 20 seconds.
Connecting to our NEW Honda 2000 generator, there is a 20 second delay, then all power comes on and stays on.
When we run the 2 generators in tandem, there is a 20 second delay, then power to the trailer cycles on and off every 20 seconds.
When the cycling happens, we can hear some sort of "clicking" in the breaker box. So far, there has not been any need to reset any of the circuit breakers.
Side Receptacle:
When we connect to the side receptacle, there is no delay when we hook up to shore power as well as either or both generators in tandem. Power comes on immediately to the entire trailer with no cycling on and off.
As long as I connect the tandem generators to the side receptacle the air conditioner works fine, as well as everything else in the system.
Based on the above, it is my impression that there is something wrong with the 3 year old Honda BUT this problem only manifests itself when connected to the front receptacle.
I figured I better find out what you folks think before I take it to a shop. Am I misunderstand how this is supposed to work... perhaps I missed something in the AS manual?
Oh, yes, I am properly connecting the gens to each other when running them in tandem.
I called the head guy at my dealers shop... he doesn't have a clue.... and frankly, THAT really disappoints me.
Please help.....
Dan
Gator113 is offline   Reply With Quote
Old 05-12-2010, 12:22 PM   #2
Gator113's Avatar
2007 25' Classic
Additional:
To be clear, when I power the trailer from my house power, all is right with the world with either receptacle.
Also, the batteries are at full charge and we have not had any other electrical issues nor have we done anything electrical to the trailer.... yet.
My brain hurts....
Old 05-12-2010, 12:28 PM   #3
Gator113's Avatar
2007 25' Classic
Sorry about this, but I thought of something else.
When I say that the 3 year old gen has low hours, this is what I mean.
I bought it new. I used it for 2 days, about 30 hours, during a power outage. I used it for about 45 minutes while we were on a month long trip on our boat. That's it...
Old 05-12-2010, 12:30 PM   #4
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I'm not going to be able to help with the answer but I think another question that might come up is:
What happens when you try to use the "older" honda for something other than the Trailer . . . say a 1600 watt blow dryer plugged directly into the generator?
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 05-12-2010, 12:30 PM   #5
_
hopefully some1 will post something useful but until then...
the delay on my unit (using the front plug) is about 3-5 seconds, not 20.
regardless it reads like u have tried all the shore/genset/plug location combos...
Originally Posted by Gator113244 View Post
I bought a Honda EU2000i generator about 3 years ago to use on my boat. I has very low hours and continues to start on a single pull and seems to be running smoothly. I have never needed to tune it....
does this mean no basic maintenance for 3 years or perhaps just oil changes?
mostly definitely begin with the basics, inspect/clean/change d'plug, clean the spark arrestor and so on.
my older 2000 gets more carbon deposits if started/run but NOT used under load regularly.
and with a minimally used/started unit 3 years old FRESH everything is important (plug/oil/clean air filter/spark arrestor)
see posts 14/18 24/25 here...
http://www.airforums.com/forums/f448...000i-5154.html
and a bit more info here...
http://www.airforums.com/forums/f448...ern-60240.html
__________
the other 'investigative trial' is to plug some HIGH draw item directly into the parallel set up and observe.
__________
btw the 'eco' button is supposed to be OFF on both units for parallel use.
some folks DO use eco n parallel and report no issues but the owner's manual suggests otherwise.
__________
it's also possible some of the connections/wires are LOOSE, fouled or otherwise buggered at the front/30 amp plug...
and the vibration of the gensets triggers the malfunction.
so try a LONG cord up front and inspect the marinco box/wires.
__________
cheers
2air'
Old 05-12-2010, 12:51 PM   #6
Gator113's Avatar
2007 25' Classic
Air2... I will cover all of those things. Thanks.
All I have ever felt needed to be done was change the oil and keep the gas clean.
The manual talks about a 20 second delay on my unit.... but I don't know jack about this stuff.
You might have identified the problem, as one thing I didn't try was running them with the eco off. I guess I missed that in the manual. Looks like I'll need to carry more gas... grrr.
Dan
Old 05-12-2010, 12:55 PM   #7
Gator113's Avatar
2007 25' Classic
If I can find the dryer, I'll give it a try. My bride never uses a dryer and anymore all I need is, well, not much. LOL
Old 05-12-2010, 01:16 PM   #8
_
the gensets also have red/yellow?/green lights on the plug side...
this SHOULD change colors IF the genset is being overloaded.
a typical household vacuum is 12-14 amps or about 14-1500 watts.
this is a good test load for 1 genset and easier to leave RUNNING than a hair dryer...
space heaters are also a good load at the typical 1500 watt size.
cheers
2air'
Old 05-12-2010, 01:27 PM   #9
Gator113's Avatar
2007 25' Classic
Air2,
Gotcha... space heater it will be. I couldn't find the hairdryer.
I'll run through these additional troubleshooting things a little later today.
Dan
Old 05-13-2010, 09:25 AM   #10
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I think what I'm confused about is the "front and side" recepticle? Is this on the trailer or on the genset? The only eu2000's I've seen are the ones with the two front outlets.. none on the side.
It sounds like for some reason the eco switch is kicking on and off on the old one, and lagging the load. Is the adapter for the shorepower tight? Do you have another 15amp adapter you could try and see if these symptoms continue? I suspect there's some loss of power that the newer one can compensate for that the older one can't. There shouldn't be so much required load at startup that it take that long to power up.. A/C is off at startup, correct?
FWIW, my EU2000 kicks in right away, no lag.
Interesting...
Marc
Old 05-13-2010, 10:51 AM   #11
_
hi marc
i agree the eco/lag issue may be at play but this is only happening at the FRONT trailer plug...
___________
a/s offeres a 'gen set prep' package for newer units.
this provides 2 marinco 30 amp connectors and an auto/changeover switch.
the 2nd/extra plug is located at the FRONT of the trailer, just above the A frame/behind the lp tanks.
while the standard juice connection is along the street side near da' REAR.
the nice thing about this feature is that shore power can be connected at either end of the stream...
which sometimes means 30 feet LESS cord.
and the gensets can be connected at either end of the trailer or left IN the TV using a very short cord.
((so the short delay (5 -20 seconds) is related to the switcher function IN the stream 4 front/side power))
cheer
2air'
Old 05-13-2010, 05:52 PM   #12
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Does your trailer have a transfer switch - to switch between shore power and generator power?
We had one in our 2004 Classic, along with a remote generator interface plug in the front of the trailer.
To make a long story short, our transfer switch was improperly wired by the factory and it almost burned our trailer down.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 05-13-2010, 10:38 PM   #13
1975 Argosy 26
1963 24' Tradewind
Ahhh... so us using "vintage units" just get used to hauling our cords around!
Ok, so yes, it seems like there might be something wrong in the trailer in switching the power front / rear.(And perhaps, a lesson on why it's not good to buy things on April Fool's Day... )
I suspect that for some reason your older gen is putting out some sort of low level surge of power every so often, making the trailer feel like it's "loosing" power.. tripping the transfer switch to the rear when plugged into the front. I also suspect that the transfer switch might "default" to the rear when power is not sensed.. so when it is on the rear plug, even if it looses power, it's already "looking" for power to come from the rear... so that's why it's not lagging switching from front to rear to front as it might do when the old gen is plugged into the front of the trailer.
Does it do this with the ECO off? Does the gen sound like it's revving up and down? Mine does this (and others have reported this) when it hasn't run in awhile. Leaving it off of ECO for a bit with a load on clears up the idle for me. I suspect the carb gets a bit gummed up from non-use.
My 2 cents!
Marc
Old 05-14-2010, 05:58 AM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Dan
Once you get the generator issues sorted out, is there any reason you can't shut down one of the generators, and turn the eco throttle on when you aren't using the a/c? (RTFM)
Also, when they're under load, the eco feature doesn't do a whole lot, only when under light or partial load. An a/c unit is not a light load, so the eco setting wouldn't matter as much.
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
I Love my Honda EU2000i Generators panabax Generators & Solar Power 30 10-30-2016 02:10 PM
Honda EU2000i dmac Generators & Solar Power 35 06-01-2010 11:09 AM
EU2000i Honda Question Bluto Generators & Solar Power 9 03-03-2009 06:13 AM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
