Old 09-04-2011, 09:34 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My AGM suddenly died
I have a 200 amp hour 41B Universal AGM battery that seems to have abruptly died. With regular wet batteries they seem to die slowly. It was working a couple of weeks ago but now it won't take any charge either with my inverter or a auto battery charger on deep cycle. I have disconnected the battery from the circuit. I probably have at least 5 years on it so I'm not complaining, just surprised at the suddenness. Is this anybody else's experience?
I have a 45 amp Intellipower inverter.
I got the battery from a guy who was recommended a lot in the forums, but forgot his name. Can someone help me?
I may get a Lifeline replacement or go wet cell with a sealed battery box.
Old 09-04-2011, 09:36 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Marshall,
Probably Randy at Best Converter in Idaho.
Bill
Just my personal opinion
Old 09-04-2011, 10:04 AM   #3
richinny's Avatar
2011 34' Classic
or mexray the battery guy in CA
or lewster the rv tech somewhere between CO and FL
Ricky
Old 09-04-2011, 10:26 AM   #4
Mexray's Avatar
1978 28' Ambassador
Morada , California
Not familiar with the number '41B', AGM...must be some Mfg's particular designation...Perhaps in view of the 200 Amp Hr mentioned, you have a '4D' battery - about 19 inches long x 8-3/4 inches wide, with both terminals at one end?
Is your old battery noticeably bulged out at the ends and sides? If so, the sulfate has built up the the point that the plates have been damaged - OR - you've got an example of extended overcharge condition, where the voltage has been elevated over time, etc...
Five years is probably about average life for RV batteries where storage/use cycles vary so much...However with proper 'care and feeding', an AGM with the proper charging equipment can last much longer...
If you wish to buy another AGM, I'd suggest you look for a Battery Specialist Shop in your nearest large city and get a quote...AGM's being heavy, the shipping costs can be a big factor if you're ordering from several States away!
Ray & Pat; Morada, CA
Old 09-04-2011, 11:25 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by Mexray View Post
Not familiar with the number '41B!
41B is the physical size of the battery.It's a biggun.
Old 09-04-2011, 05:15 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
This winter it got down to 35 below. I wonder if that did it!
Old 09-04-2011, 10:22 PM   #7
2005 19' Safari
GLENDALE , AZ
We had an Optima Blue Top die, like you had turned off a light switch. It probably developed an internal short in one of the cells. Ours had the voltage drop from 13.5v to 10.5v, which is pretty much useless. It was four years old.
Phoenix is online now   Reply With Quote
Old 09-05-2011, 12:57 AM   #8
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
The Optima Red Top in my TV did the same thing...4 years old, and just quit.
Phrunes is offline   Reply With Quote
Old 09-05-2011, 08:36 AM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by Phoenix View Post
Ours had the voltage drop from 13.5v to 10.5v.
In my case the voltage has dropped pretty much to zero. Can't find my multimeter, but with my 12v test light when the charger is on I get a light across the terminals. Soon as the charging current going into the battery is turned off no light.
One of the batteries died HiHoAgRV Batteries, Univolts, Converters & Inverters 3 08-22-2011 01:48 AM
Do AGM batteries provide more power? Bill M. Batteries, Univolts, Converters & Inverters 11 08-10-2011 11:10 AM
AGM battery fumes? pickerdd Batteries, Univolts, Converters & Inverters 7 05-25-2011 09:28 AM
Optima AGM Red Top start Battery Install John H. Classic Motorhomes 8 03-19-2011 09:17 PM
AGM equivalent? UAPachyderm Batteries, Univolts, Converters & Inverters 22 01-31-2011 08:44 PM
