Hi - I was wondering if someone could help me figure out my electrical set up...or point me to a forum post that has the answer.
I'm in the process of replacing the flooring in my 86'
Sovereign and building a desk up front. I want to move the converter and inverter that sit on the inside of the battery boxes to the outside of them (for desk chair leg room).
This is the layout:
The inverter on the right has plenty of cord to be moved to the right side of the battery box.
The converter on the left doesn't have much wiggle room at all. In the pic below you'll see the white & black wire going up into the wall off of the silver box. This is what's limiting me from moving it to the left.
My question is can this wire be spliced and extended - and if not what are my options? The other question is where does it connect to? Thanks for the help...
As a side note - I have replaced the entire trailer with LED lights and most of the power consumption will be using laptops and monitors. Are there any things to look out for when using somewhat sensitive electronics with older electrical equipment?
