Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-04-2006, 11:57 AM   #1
dmadam
Profile:  1983 34' Limited
Henderson , Nevada
Moving the batteries
I want to move the batteries from inside and place them ovet the hitch frame. Has any onedone something this and anyone have suggestion/thoughts.
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 03-04-2006, 12:55 PM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Never done it, but it would seem fairly straight forward. If you got one of those battery boxes that the newer Airstreams come with, you could have it welded to the A-frame in the same location, then all you'd have to do is pull the wire(s) from the current location to the new battery box. At least that's how I think I'd start to approach it. One neat thing to this is that if you have only one battery currently, you could very easily with the box mentitioned above, go to the standard 2 batteries most coaches now have.
Old 03-04-2006, 01:36 PM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
There are various threads talking about wiring (not my expertise). Is your current battery under a front gaucho? Moderator johnhd is a good one on this issue -- but you've got to be cautious about lengthening the run between battery and Univolt. Proper gauge wire is also important. Proceed with ... full knowledge! Try any number of search strings. Most of all get some good info from our more electrically inclined members.
All it will take is looking closely at the double battery setup of new units to get you hooked! Good luck.
Old 03-04-2006, 03:40 PM   #4
CanoeStream
Images: 13
This isn't my topic of expertise at all -- but a number of suggestive links turned up when I searched on keywords: battery gauge
Also: gauge distance
Old 03-04-2006, 07:01 PM   #5
Ken Sands
Keysken
Ken Sands's Avatar
Profile:  1982 31' International
Clarkston , Michigan
You could also get a $ 175.00 non hydrogen venting glass matt battery, and put under gaucho,. Thats what I did.
Ken Sands is offline   Reply With Quote
Old 03-04-2006, 09:28 PM   #6
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Agree with Ken
IMHO, AGM's are the way to go. I have changed out my stock new Interstate group 24's with Lifeline AGM's. They are a far superior battery, much safer, and no maintenance. Just be sure that they get the proper charging voltage.
It would probably save you in the long run to change both batteries and leave them where they are: no new battery box to be fabricated, no new cabeling and a much longer life span.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-04-2006, 09:58 PM   #7
Bob Thompson
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
Although I haven't done it to my Airstream, it's predecessor, a Scamp 5th Wheel had the battery on the front frame, near the propane tanks. It was in a plastic boat-battery box. Similar thinking could be used on an Airstream.
2002 Toyota Tundra
GM, Ford and Chrysler execs can save money like the rest of us by driving fuel efficient quality cars. Honda and Toyota would be a good place to start looking!
Bob Thompson is offline   Reply With Quote
Old 03-06-2006, 12:42 PM   #8
dmadam
Henderson , Nevada
Thumbs up Thanks all
You all had good ideas and I have gone ahead and implemented the task. Pretty much the way Bob Thompson suggested. I pulled the old battery boxes out. They were under the old goucho which I have removed and would have been the way of the new layout I am making inside. I am putting a plate over the hols left by the boxes and using the same cables to hook to the new batteries (in new boxes) and placing on the hitch frame behind the propane.
Looks good, easy hook up, more room inside and easier access to them.
When completed I'll post a pix.
Thanks again
David
Old 03-06-2006, 02:28 PM   #9
Silvertwinkie
Aluminut
Lew, I thought I had read somewhere that the power converters in the Airstreams cook batteries over time. I had thought about AGMs, but felt the converter in our 2004 would in fact burn them up in the end.
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 12:58 PM
Batteries & Solar Charles Q Treichel Generators & Solar Power 0 09-16-2002 09:50 PM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 10:05 PM
Univolt/Dual Batteries uwe Batteries, Univolts, Converters & Inverters 4 06-28-2002 09:26 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 11:01 PM
test
