Old 09-29-2008, 08:04 PM   #43
1975 27' Overlander
saucier , Mississippi
Rivet got pics working
let me know what u think dont hold nothing back lets here all feedback good or bad
clinton2292 is offline   Reply With Quote
Old 09-29-2008, 08:36 PM   #44
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Just my 2 cents
I sure wish there was that much room for servicing my genset mounted in my MH. Make your enclosure removable for this reason. Are you going to hardwire it in with your converter like a MH? I was at a recent rally where electric wasn't available. Some Airstreamers were talking about how long it took to charge batteries by plugging in trailer to generator. One smart fellow had a great idea to avoid taking 1/2 a day to charge this way. He disconnected the battery & used an ordinary battery charger plugged into the generator. I didn't see any louvers on the outside door in your photos. This might cause a heat build up in the compartment. Insulation can only help so much.
3 Dog Nite is offline   Reply With Quote
Old 09-29-2008, 08:55 PM   #45
1975 27' Overlander
as far as the outside door i am going to leave it open when i run the generator that is why i mounted it upside down so i would not have to prop it open when in use and yes i already wired an automitic transfur switch so when i start the generator it will power everthing up and there is no chance of beckfeed to shore power or the other way around
Old 09-29-2008, 08:56 PM   #46
1975 27' Overlander
i also have a lp gas kit on the way for genset
Old 09-29-2008, 11:57 PM   #47
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, clinton 2292. I was picturing a newer unit in my mind when you said 4.0 Kw. [micro light] That looks just like my old 6.5 Kw. Is your generator mounted to the plywood floor? Is there any frame work under this area? Are you going to box it in and seal it off really good? We don't want any exhaust fumes coming inside. If your generator is anything like my old 6.5 Kw was, it will shake your trailer pretty good whenever you start it and shut it off. [like a mild earthquake] My 7.0 Marquis was real smooth in comparison on start, stop, and running. Good job, Good luck, and keep us updated as you go.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-30-2008, 06:31 AM   #48
1975 27' Overlander
it will ne mounted to the floor but the frame runs right under the center of it so it will be mounted well plus it sits right over the stablizer jack as far as the cover it will be well sealed plus the exhaust will be run out the side i will post more pics as i get more done
Old 09-30-2008, 08:42 AM   #49
2005 30' Classic
Images: 12
Clinton,
I would suggest going to Onan and getting the specifications on your genset. The air intake has a ratio to the exhaust. In fact, they should have a template that you could place on the floor for the cut-outs. For fire protection, you might also want to put some metal on the wood floor.
The attached picture is an example of what I did (before all the trim was in place . . .).
GetOutDoors is offline   Reply With Quote
Old 09-30-2008, 09:00 AM   #50
1975 27' Overlander
i am going to cover the wood floor in a fire proof roll on insulating sound deading stuff kinda like truck bed liner as far as the air intake my install manual says free air in no less than 8x10" and the exhaust is also to size per the manual
Old 11-03-2008, 07:03 PM   #51
1975 27' Overlander
Install complete towed it about 200 miles all seems well installed co dector ran gen all night no probs
Old 11-03-2008, 08:23 PM   #52
Central , Mississippi
Great Job! That would have come in handy when we were at your local Kart track a few years ago and the temp and humidity were both approaching 3 digits.
Your Genset does look alot like my old 6.5 Kwh
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-04-2008, 09:15 PM   #53
1989 34' Limited
toronto , ontario
clinton2292 having installed a gen on my unit I can appreciate the thought and effort put into your gen. project. However if I under stand correctly, you slept the whole night with your gen. running. People die in houses with cars running in open garages another case barbequing with the garage door wide open, with no visable entry for CO gas to enter the houses.
I would get 2 or 3 CO detectors in my unit, better still dont sleep with the gen. running.
CO enters your white corpusels in the blood stream making you sick + headack then paralizes you, next a coma, the only cure is a hyperbaric chamber, there is also a point of no return and the chamber will not work.
hope your not too upset with my post.
letsgo123 is offline   Reply With Quote
Old 11-05-2008, 05:16 PM   #54
1975 27' Overlander
No not at all poeple sleep in motorhomes all the time with gen running it is sealed from the living area and the exhaust is vented outside as for as the co detector i would hope the kiddy the maker of the dector would make the alarm sound well before levels got harmful it also has a readout of ppm and it stays at 0 and yes i have tested it
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Regulator Mounting? dnrtheil LP Gas, Piping, Tanks & Regulators 2 04-03-2008 11:27 AM
Mounting televisions DrPlay Audio, Video & TV 7 02-14-2008 08:30 PM
tv mounting katsix Audio, Video & TV 4 01-01-2008 08:01 AM
Television Mounting jrk247 Audio, Video & TV 5 08-28-2006 03:41 PM
