Old 07-07-2015, 12:21 PM   #15
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Here's a propane conversion kit for a 3600w Ridgid with a Subaru engine:
RD903600 Generator Tri-Fuel Natural Gas and Propane Conversion Kits
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 07-07-2015, 01:18 PM   #16
BigButtUgly's Avatar
1958 22' Caravanner
not shared , Nebraska
For phawk33. Loved what Protagonist had to add (because of what I did.) Mounted a 142# dual fueled 3500 watt on the tongue and eliminated full 20# bottle use, although I keep a 20 pounder forward in my Escalade EXT (a fancy pickup) for emergency use and to refill my 1 pound bottles. So I do not know how you'll handle your 20 pounders which you are unfortunately tied to. In the Jeep or elsewhere you will be required to store bottles in a sealed or vented vessel as 20 pounders can "gas' i.e. "vent". On my wheeled generator I added 2 removeable 19" dropdown extensions on the side opposite the roll around handles. These drop downs have the wheels attached. To remove the generator I bolt on these extensions and flip up the handles an remove the generator from the tongue. I only move the generator inside the AS when away ( to prevent theft). But this is easy for me as I no longer have a step. I use a slant ramp sometimes and am in the process of an airbag suspension retrofit to for a full kneel down. This to make an easy step up height when ramp is not in place. Since my 1958 Caravanner frame was not to be trusted I added 2" "L" angle steel front to back on each on each rail. Therefore I eliminated any frame flex at front or rear. I put my spare on the rear bumper modified to resemble the 1950s continental kits on cars. I don't how you solve your possible frame issues. My weight and balance was easy for two reasons. First, on a single axle like mine = simple calculations but yours not so. Second I gutted the Caravanner to 2180 pounds and replanned the interior to an exact 300 pound tongue weight. Easy for me as the EXT holds wood (for wood stove heat), kerosene, gasoline, 1 gallon water bottles, 18 each point source 1 pound propane bottles, the slant tamp, Foldable "Little Red Wagon" et.al. I do not have a propane frig, propane hot water heater ( I use a pressurized turkey fryer with foot air pump for shower), or installed stove/ oven. You'll have to leave propane on tongue , use the generator and spare tire for balance . I do not envy your problems.
BigButtUgly is offline   Reply With Quote
Old 07-08-2015, 04:56 AM   #17
2014 25' FB Flying Cloud
Richmond , Virginia
Lots of options to consider but definitely not mounting on the bumper!
After careful consideration I have opted to build a light, plywood enclosure to place over the generator inside the SUV. The enclosure will be fitted with a polyethylene liner to enclose the fumes harmless. We'll keep you posted how this works.
Thanks again for the many responses from the Community!
phawk33 is offline   Reply With Quote
Old 07-08-2015, 04:28 PM   #18
LOGRIDER's Avatar
2014 27' FB International
Avila Beach , California
Colleas,
Nice to see the Lil Nomad is still kickin' it.
Dennis and Pam
Logrider
"don't let life get in the way of living"
LOGRIDER is offline   Reply With Quote
Old 09-30-2015, 01:20 PM   #19
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
We use these on set. You could set up a "train?"
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 09-30-2015, 03:29 PM   #20
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Personally, I feel Airstream should get with it & engineer a built in propane generator for those willing to pay for it, I know I would.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 09-30-2015, 03:44 PM   #21
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by phawk33 View Post
My question has to do with the possibility of mounting a small 3600 Watt Ridgid Generator (130 lbs) on the rear bumper because carrying the generator in the back of the Jeep means inhaling gas fumes before the TV gets moving.
Are you towing with the generator running?
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Bumper Storage Compartment Door Mounting Ideas dbj216 Exterior Storage Compartments & Access Doors 9 07-23-2015 09:58 AM
How to get 12V inside rear bumper of 25FB Anders79 Electrical - Systems, Generators, Batteries & Solar 9 03-05-2015 08:12 PM
LED TV mounting on a Safari 25FB MHBroker Audio, Video & TV 3 05-17-2013 03:28 PM
mounting generator clinton2292 Electrical - Systems, Generators, Batteries & Solar 53 11-05-2008 05:16 PM
