Old 04-09-2006, 09:39 PM   #1
Mostly good power after Univolt was replaced...
After replacing the Univolt in my 1981 Excella 2 with a Parallax 7400. It was easy to swap this in and everything worked. I have to figure out how to rewire the Power On light and control panel but there is info on this forum for that. If anyone has a step by step for rewiring the Power On light for someone with just enough electrical experience to do this, I would appreciate getting it.
My issue is that even though the converter is supplying the right amount of power, a 12 volt car stereo that I installed will not work. It blinks on and off when I connect the power or it blows one of the inline fuses. Why would the fuse inline for the stereo blow and everything else in the camper work fine?
Thanks.
ricjones1138 is offline   Reply With Quote
Old 04-10-2006, 06:39 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Check your polarities and be sure that all the grounds go to negative and all the power feeds go to positive. Also look for a short to ground in the wiring somewhere in the circuit. Take the inline fuse out and check the feed wire with a 12V test light or meter and verify that you are getting +12VDC in that wire.
Brakes good enough? Jabba Brakes & Brake Controllers 7 10-14-2002 03:43 PM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 10:01 AM
'67 Tradewind: Where is my Univolt ??? Mike Rhodes Electrical - Systems, Generators, Batteries & Solar 5 07-21-2002 06:03 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
