Old 11-21-2019, 05:28 PM   #1
dropped rivet in grass
2019 23' Flying Cloud
Tarzan , Texas
Moisture in Backup Camera
Hi all,
Sorry if this is the wrong forum to post this question.
A quick search of the forums didn't show anything specific to my quandary, so..
There is moisture on the inside of the backup camera of my FC. The antenna was loose, and I assume that's the entry point.
How can I dry it out? It doesn't seem to be "plug n play" where I can just unplug it and stick it in a bag of rice. Any tips?
Tall Grass is offline   Reply With Quote
Old 11-21-2019, 06:10 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
My BU camera was penetrated by Hurricane Florence. Opening it up would have violated the warranty on it, but I opened it up anyhow and was unable to dry it out. I had to buy a new one.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-21-2019, 06:28 PM   #3
2018 27' Globetrotter
Elbert , CO
A session with a warm hair dryer or heat gun (not too close!) might get the condensation out.
djb75 is offline   Reply With Quote
Old 11-21-2019, 06:39 PM   #4
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
I had the same problem, I also opened it up and let it dry out only for it to steam back up. I called Voyager and told them my story, without question they sent me a new one no charge after I sent mine to them. I was very impressed with their Customer Service.
Gary
Castaway is offline   Reply With Quote
Old 11-21-2019, 06:56 PM   #5
Tarzan , Texas
I'd be interested to know how you replaced it. If it's not plug n play, I might be better off having a pro do the job.
Old 11-22-2019, 11:36 AM   #6
We had the same problem.
After giving it ample time to dry out, it didnít, so I called Voyager.
They were very good. They sent me a return authorization number, I followed their directions for returning the camera, they sent a new one at no charge. Easy as that.
Install was quite easy. The wires plugged in to the existing ones, no wire stripping or crimping involved. I just made sure the mounting bracket was well sealed to the trailer with silicone.
Before installing, I also siliconed everywhere that I thought moisture could enter the camera. Hopefully I got it all sealed.
WHERRWE is offline   Reply With Quote
Old 11-22-2019, 11:50 AM   #7
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
One of my two cameras had the same problem. I opened it up (being very careful), used a 'Q' tip then a hair dryer. Before reassembling I placed two of those bags that come in pill bottles to soak up moisture and used silicone on the opening areas including all screw holes. A few months later I noticed I had not put enough silicone on the openings so took it apart and did the job again. So far, so good. Only problem is sometimes the signal from the camera to the monitor does not work. I may have to order another camera on eBay from my dealer in China. It is very similar to the Voyager but about half the price.
Name:	Backup Camera System.JPG
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Old 11-25-2019, 11:02 AM   #8
2019 22' Sport
Waynesville , Missouri
Camera Issue Solved
Originally Posted by Tall Grass View Post
Hi all,
To get the water out without disassembling??? Maybe if you set a hairdryer close enough to it to vaporize all the water inside so it can cook out. I didn't want to wait and carefully disassembled it. The problem is not your antenna, it's the glass-to-body interface. There is no seal between the glass and body!!! Water is running down the glass right into the camera body. I solved the whole issue by drying out the camera first, then putting a thin bead of outdoor proof silicone sealant around the edge of glass. It doesn't affect the picture if you keep it restricted to just the where the glass touches the camera body. All water penetration stopped after that. Very irritating that a company would sell and outdoor camera that isn't sealed against water.
DAVSCH is offline   Reply With Quote
Old 12-01-2019, 07:47 PM   #9
Rusted's Avatar
2013 Interstate Coach
Brooksville , Florida
Plastic bag and some rice...place rice a hand full in a sandwich bag wrap it around the camera use a rubber band and park in the sun ... leave it for a day or two. The rice will absorb the moisture.... worked on mine.
Rusted is offline   Reply With Quote
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 07:09 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 01:31 PM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 01:23 AM
Intec backup camera Bill McNamara Airstream Motorhome Forums 2 04-15-2004 03:41 PM
