Old 04-14-2011, 01:25 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Modified umbilical
I have found the now-standard trailer umbilical to be problematic on several counts.
  1. The cable tends to get caught on hitch components and pulled out or damaged.
  2. It is inconvenient to repair the cable and connector safely because there is no way to switch off the charge line without disconnecting all sources of 12 volt power (converter, batteries, solar).
  3. When circumstances require a change of tow vehicles, the cable length and connector type are often wrong. Adapters are a source of problems and also contribute to the cable getting caught or dragged.
I placed a round-pin 7 way of the type used by semis on the bottom of the A frame where it is protected by the WD bars, and used a support spring attached to the tongue jack head to hold the cable up and out of the way while still allowing movement during turns.
Old 04-14-2011, 01:36 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
A few more photos
ID:	126999   Click image for larger version
Old 04-14-2011, 01:44 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I like the idea. I have often thought about doing this myself.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 04-14-2011, 03:41 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Very nice work; looks good.
Brian
SuEllyn & Brian McCabe
Old 04-14-2011, 03:47 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks great
Good idea.
In reference to the charge line being hot all the time. If yours is wired like mine; there is one fuse to pull to kill the 12 volts from the house battery etc. I'm guessing it would already be disconnected from the TV if you're having problems.
Old 04-14-2011, 03:51 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Nope. It goes through a self-resetting automotive breaker and there's no manual disconnect.
Old 04-14-2011, 04:14 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
Jammer, I thought we have a "kill switch" to battery power under the sofa of our Airstream models?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-14-2011, 04:20 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes, but it doesn't shut off the power to everything. I believe that the converter, the umbilical, and maybe the breakaway switch stay hot.
Old 04-14-2011, 04:34 PM   #9
1985 31' Excella
Fresno , Texas
I believe the jack and the emergency brakes come directly off the batteries.
Wsmith is offline   Reply With Quote
Old 04-14-2011, 04:40 PM   #10
1985 31' Excella
Fresno , Texas
The sofa switch kills every thing on 84,85,86 models
Old 04-14-2011, 05:42 PM   #11
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Why not just install a battery disconnect? They cost about $5 and connect directly to the pole of the battery. I got mine from Batteries Plus and use it to disconnect my house batteries over the winter. Otherwise, there is a constant drain on the batteries from things like the carbon monoxide monitor, etc.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 04-14-2011, 05:52 PM   #12
dznf0g's Avatar
Oswego , Illinois
I think the battery disconnect varies (like just about everything else on these trailers). Mine leaves the brake actuator, co detector, umbilical, and breakaway switch on. My jack has no power. I have roughly 100ma draw with the switch off. My monitor only has one place to the right of the decimal point and it moves back and forth between 0 and 1. So somewhere around 100ma, depending how the monitor rounds off. Actually I moved my co detector to the other side of the switch since I'll never be in the trailer without the switch on, so the 100ma is without that detector on.
Old 04-14-2011, 07:23 PM   #13
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Very cool idea and implementation!
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 04-14-2011, 11:26 PM   #14
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
If anyone is intrested, there is a coiled embilical available. You might find it at larger truck stops or at your local Freightliner,PETERBILT, Kenworth,International Dealer or ANY Heavy Duty Truck supply Store.
I think both ends will be the same but came be rewired into a 7 way flat blade plug for the TV end.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Running lights and taillights out steven2themax Lights - Interior & Exterior 53 08-09-2014 06:41 AM
Almost a new owner of a 77 Safari Scottcoda Member Introductions 17 03-24-2011 09:19 PM
