Old 05-18-2016, 11:21 AM   #1
1976 31' Sovereign
ompah , Ontario
Missing thermostat for furnace 76 sovereign
All I've got is a few wires coming out of the wall next to the fridge on a31 footer.What's best approach to replacing it?Not clear if my 77 manual applies to a 76 model. Thank you .
PS New to forum how will I locate any responses to this ? Will I get an email back or just rummage around on the forum for my Title?
fast fredy is offline   Reply With Quote
Old 05-18-2016, 11:35 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
ONE - welcome to Airforums! We'll help you through the initial steps. Look up on the bar that starts UserCP ---go right until you see New Posts - that gets you a lot of the current responses starting (usually) where you last read on a thread. You can revisit any thread you started or made a post on by using Advanced Search and on the right hand top just putting in your own User Name. Also If you have a current thread that you've posted on like this one, click on your Avatar(picture) and select "find other threads by..."
Also thoroughly study UserCP - it's your control page - you can ignore threads that don't interest you, set up notifications when someone posts to a thread you follow or post on, etc.
If you think you've really screwed something up, put a plea into the Moderators - they're the ones on the user list at the bottom of the page whose names are in bold... they can delete a post or redact it or even help you change your user name. When I started I was "Tin Lizzy"
Oh, and a missing board on a furnace. Had one stolen from my EB. Someone with a SOB had been stealing them for months - and finely nearly fried himself putting the last one in HIS furnace. Should have figured that if they kept blowing out, there was a short somewhere in his system. Can't tell you that much about older units - but you can go to www.Airstream.com and find .pdf's for a lot of older models including their appliances.
Happy hunting. Paula
Old 05-18-2016, 03:21 PM   #3
You can use most any good household type thermostat.
You can get them at stores like Home Depot.
Old 05-18-2016, 03:47 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi fredy,
I would go ahead and upgrade to a digital thermostat for the convenience. I believe I used a Honeywell unit cost less than $30.
Aaron
WBCCI #XXXX AIR #2495
Old 05-18-2016, 05:12 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Those wires do not have anything to do with the furnace. The thermostat for the furnace should be in the bedroom area, near one of the light fixtures on the aft bulkhead. The wires you found are for the air conditioner only, and unless you still have the OEM air conditioner, are likely disconnected at the other end, as well.
sovereign
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 08:54 AM
Replacement thermostat for Suburban furnace SafeHarbor Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-09-2005 10:14 PM
Digital wall thermostat for A/C and furnace nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-21-2004 08:03 AM
Furnace Thermostat neil.ervin Furnaces, Heaters, Fireplaces & Air Conditioning 15 11-27-2004 05:45 PM
furnace fast cycling - thermostat adjustment emanon25 Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-28-2004 09:06 PM
