Old 06-29-2017, 01:34 PM   #1
slpiotro's Avatar
2007 23' Safari SE
Madison , Wisconsin
Send a message via ICQ to slpiotro
Microwave Power Use
I installed a solar system with 2000 Watt inverter so that I could use my micro to heat a cup of coffee etc. It worked fine for a couple of years, but then it would kick off after a few seconds use of the microwave. Tested the Inverter by doubling up the hair dryer and other appliances, and it is clearly the initial surge of the micro that kicks out the inverter.
Question, it works fine on shore power (but I am certain it puts out a load on the shore power), so what brand style would you recommend for replacement. I don't want to just replace it with another model made for the house and subject it to the bounce of the trailer and end up with the same issue. Any brands made specifically for travel trailers? I had little luck searching the net for heavy duty microwaves.
Thanks.
"Honor those who serve by listening to them and caring. Parades end, caring needs to be there every day."
slpiotro is offline   Reply With Quote
Old 06-29-2017, 01:40 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You better investigate your batteries. Most inverters will have a low voltage cut off. If your batteries have degraded, the surge from your microwave on inverter could be enough to trip it out. You need to be watching battery voltage on a meter before, during, and after running the microwave.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-29-2017, 02:32 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would try a know good battery or put a volt meter across the current battery and then turn on the micro wave and watch the voltage drop of the battery.
2004 Excursion 4x4
Old 06-29-2017, 03:12 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Unlike compressors, microwaves do not have a giant / long energy spike right at startup. If anything it takes them a bit to get going. You obviously have a problem. Like the others I'd guess it's related to the amount of power being pulled rather than some weird characteristic of the microwave.
Old 06-30-2017, 09:19 AM   #5
slpiotro's Avatar
2007 23' Safari SE
Madison , Wisconsin
thanks, but
The batteries were brand new, in fact installed as part of the check out. Tried every other power hungry thing, it did not kick out. It was only on microwave. I will run the voltage tests etc. but the batteries are not the problem. Mostly I was looking for advice on microwaves that stand up to the travel bounce.
Power outage while on batteries (Flipping use/store switch restored power) TwoSporks Electrical - Systems, Generators, Batteries & Solar 11 12-13-2016 12:06 PM
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 11:58 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 05:34 AM
Do you use your microwave? sempi2 Stella's Kitchen 33 06-28-2011 07:45 PM
For adding a convection/microwave. Can I use wiring WILDRTEXAS Stoves, Ovens & Microwaves 16 06-05-2010 02:38 AM
