Old 10-03-2019, 05:22 AM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Microwave draws 15A?
I was at a campground last week with some voltage issues so I was monitoring my use fairly carefully. My AS has the provided Microwave/Convection and I assumed it was about 800w, but when I used the Microwave it used 15A on top of the small load I had from the refrig. I couldn't believe it but repeated that numerous times. I have never checked this out but I have never seen a microwave rated at 1800 watts. Maybe on convection oven mode, but just a microwave?
Larry
lsbrodsky is online now   Reply With Quote
Old 10-03-2019, 05:39 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have an older Microwave that does draw about 15 amps. It occasionally trips the 15 breaker. It draws more than the AC when I am running on generator. The draw does not seem to be steady. It sorta waves up and down. I have not done good metering. But in looking at the surge protector amp readout that is what I get. Which is sorta interesting in that the max output for the generator is supposed to be 13.5 but it sits there reading 15 on the surge protector running just fine.
Bill M. is online now   Reply With Quote
Old 10-03-2019, 06:38 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I can run my AC on my Honda 2000 generator (on propane) but not my convection microwave. If you have the manual, check the specifications for current draw.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-03-2019, 07:38 AM   #4
lsbrodsky's Avatar
OK, I did that. Specs are 12.5A microwave, 13A convection/broil 900w microwave output power. With those specs, should run easily on a 15 amp circuit, nothing else on, but my 15A measurement was accurate. Nothing I can do about it or need to do about it, but I never considered that the microwave was quite that much of a load. I never try to use A/C or electric hot water with the microwave and I make sure DW is not using a hair dryer. Be aware!
Larry
Old 10-03-2019, 07:55 AM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Was your converter charging your batteries? I donít know how many watts that uses....also have no idea if that question is even relevant so go easy on me
SteveSueMac is online now   Reply With Quote
Old 10-03-2019, 09:45 AM   #6
lsbrodsky's Avatar
I don't really have a converter anymore and the Lithiums were fully charged on solar float. The amps before turning on the microwave were 2, all attributed to the refrigerator. I tested numerous times and the total amps went up to 17. I am confident the microwave is drawing 15.
Larry
Old 10-03-2019, 11:15 AM   #7
Were the specs given in amps, or did you go back to amps from watts and 120 volts? The power factor is likely not 1, so the amps will be more than you would calculate. Just guessing.....
Al
S/OS #004
Old 10-03-2019, 11:44 AM   #8
lsbrodsky's Avatar
The specs were given in amps, but i would expect a power factor of 1. There is really nothing inductive in a microwave oven except a small motor.
Larry
Old 10-03-2019, 12:27 PM   #9
lsbrodsky's Avatar
I'd like to note that I did some browsing on Amazon of similar microwave convection ovens and they all have very similar ratings. My ammeter is giving me expected readings for the A/C and refrigerator, based on what many people have reported for their units, so I have to believe the reading of 15 amps for the microwave. On the inverter, that is still not many amp-hours to heat something with the microwave, but for people who do not have a hybrid mode when on the generator, a small generator may not carry the load.
Larry
Phantom battery draws Meeks Batteries, Univolts, Converters & Inverters 6 12-07-2016 01:15 PM
Monitors/ Phantom draws on DC power ads99 Boondocking 10 11-09-2016 01:30 PM
Parasitic draws and 12V system M and M Boondocking 20 12-13-2015 08:31 PM
kitchen draws coming apart billiards Cabinets, Counter Tops & Furnishings 2 09-08-2009 08:13 PM
30A or 15A ...in 67 Safari aircooled4 Batteries, Univolts, Converters & Inverters 3 01-07-2009 01:41 PM
