I have a 2004 Classic 28. The sensor locations are correctly identified in the prior posts compared to my system.
Eight weeks ago, I installed the SeeLevel 709 system for $200. I was able to reuse access holes already cut in the belly pan (one by the factory and one by a previous owner) to install the electronic strips on the fresh water and on the black water tanks. I cut a new hole for the gray tank to maintain the distances from sheet metal recommended for the SeeLevel installation. I reused the wires from the MicroPulse to hook it up to the monitor I installed in the kitchen where the MP monitor was. The system works great and gives very accurate readings.
If you want more particulars on how I did the installation, send me a PM.
