Old 01-07-2015, 11:28 AM   #29
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by crispyboy View Post
I have a 1994 30' trailer. If I remember correctly I believe there is a junction box that can be seen in the left rear compartment of the trailer. This should be where the shore power cord termination point can be accessed.
Thanks. I'll take a look next time I'm in there.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-07-2015, 11:43 AM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
POI.....
Make sure EVERYTHING in the trailer is TURNED OFF before plugging in. Dielectric grease on the prongs will prevent the oxidation.
I always plug in our EMS-PT30C into the tower to ck for issues.
Old 01-08-2015, 05:58 AM   #31
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by idroba View Post
My general feeling is that there will be more wear, problems and need to replace things with the detachable cords over time than with the permanently attached ones. This is mainly due to the weight of the cord at the wall outlet and the additional set of contacts and resistance plus heating they cause. Probably the very very best quality ones might not have issues but the plastic ones that Airstream supplies will be much less rugged and will fail more often, over time, than permanently attached cords.
What I'd like to do with ours is install the detachable fitting where the cord comes out of the body of the trailer inside the current cord storage bin. Then, I'd leave it attached 99% of the time, but I'd be able to detach it if there was an issue of some kind. I don't know if this would work in the space I have there, though - I don't plan to do it until it becomes an issue or I'm REALLY bored and all of my other, more pressing issues, have been resolved - probably right around the time peace on earth breaks out and Congress actually starts working together.
Reading this thread reminds me of a thought that I have every time I'm dealing with our cord storage: "This wasn't one of Airstream's better designs." The odd thing is that I had the same thought for every cord storage design I've dealt with on Airstreams - from just laying it in the rear bumper, to the spring loaded reels, to the space under the shower in the B190, to the sliding metal bracket thingy on our '95 trailer. So I guess Airstream is just keeping that tradition alive with the current cord setup, too.
Old 01-08-2015, 06:41 AM   #32
dznf0g's Avatar
Oswego , Illinois
Let me ask a question. Since storage is at a premium in our ASes, and the cord is always the first thing unloaded and the last thing loaded, why do we use our storage compartments for the cord?????
I finally realized this some time ago, and now just throw the cord into the back of the truck, on top of....whatever. When the AS is in storage, I just lay it on the floor inside the door. Again, it'll be the first thing I take out when I arrive home or at a CG. If boondocking, it is on the floor of the truck...under everything else.
-Rich-
Old 01-08-2015, 07:05 AM   #33
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Skater,
It seems that you are thinking about changing out your shore power cord to the twist lock type.
My opinion after using both is that the original design (cord hard wired to the trailer) works better.
My sister owns a 2008 Safari with the Twist-Lock type of connector. I have used it a few times and I think it is a PAIN IN THE REAR END.
Why?
1. Lining up the prongs can be a pain.
2. Threading on the locking collar is a pain
3. There is always the possibility of theft
I once thought about doing the same project (converting to the twist-lock cord) on an older trailer with the trunk shore power cord setup. Hind-site I'm glad I didn't do that project.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-08-2015, 07:48 AM   #34
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Had the same thing happen on our new 2008, a couple years down the road.
Took trailer to J/C to get checked-out
Rick told me coach was fine, and it was a run of bad cables (that were somehow not recalled)
Gave me a new HD cable
Haven't had problem since
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Oohh that smell..Melting plastic? ArgosyGypsy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-16-2011 11:08 AM
Lens melting w/1141 bulbs HCR Lights - Interior & Exterior 9 03-04-2011 12:37 PM
Patio Light Reflector Melting JBinKC Lights - Interior & Exterior 12 09-02-2010 11:46 AM
Flood light lens melting nickcrowhurst Lights - Interior & Exterior 5 12-24-2003 08:38 AM
