Not sure what an mdl designation is but you got the newer version of the 7355 lower converter. The 8355r is the same basic lower component except they are about 3 inches deeper. Not a problem as long as you are not backed up against a water heater or something behind the original that would present a physical problem. Still single stage you know
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
