Old 08-29-2013, 08:41 PM   #1
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Maxi-fan problem
I have my AS parked near my house and plugged in to my 110. I had my Maxi-fan in the bedroom set for 85 and it has been working fine. I went in today after 4 days and the motor was running to lift the lid and nothing was happening. I shut off the thermo and pulled the lid turner down and nothing, it would not turn or connect with the gears to lift the lid. Any suggestions?
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-29-2013, 08:50 PM   #2
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
You did not say, but I assume you turned it back on after you pulled the knob down. Sometimes you have to turn it a little bit to get it engaged.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 08-30-2013, 03:20 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Mine doesn't have the "power open" feature; I have to crank it by hand. But the worm gear on the inside end of the knob of mine stripped out and mine wouldn't open when I turned the knob. I was able to get a replacement shaft with the gear on the end from the manufacturer. Can't remember how much it cost, but it wasn't terribly expensive.
Side note, the reason mine stripped out was I cranked it too hard trying to get the vent tightly closed, on more than one occasion. The worm gear is only pot-metal, so it will strip out easily. Better that easily-replaceable part strips out than something harder to replace inside the fan body!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
