Old 05-13-2011, 08:17 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Master Switch question
I have a 1985 Excella 31'er. Located behind the sofa on a shelf below the front window there is an on / off master cut off switch for the batteries. What is the rocommended use of this switch. Should I bother with it at all or is it for use when parking between trips or for long term storage. I usually remove the batteries for winter storage and keep them on a tender at home so I guess the storage issue is a non-issue.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
A Switch with no apparent function Aviator Lights - Interior & Exterior 8 01-24-2011 06:18 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
