Old 09-21-2013, 06:34 AM   #1
2005 28' International CCD
Golden Valley , Minnesota
Master kill switch
I have a 2005 International and want to know where the master kill switch is. Can't find it in owners manual. I have AGM batteries and normally pull them out over the winter - then I keep them in my garage and periodically throw them on my BatteryMinder charger. Someone suggested just using the master kill switch and leave the batteries in place over the winter but I have no idea where it's located.
HilaryStep is offline   Reply With Quote
Old 09-21-2013, 06:47 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Don't you have the switch by the door with the red LED and the "use/store" option? That's your switch, and it doesn't shut everything off.
Old 09-21-2013, 07:20 AM   #3
Yes, I do have that but like you said, it doesn't shut everything off - there's still a small amount of power coming thru. I am referring to the master kill switch which will kill ALL power. I understand it is a knob/handle type thing that you turn. I looked under the front couch to no avail.
Old 09-21-2013, 07:29 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Way up North...
I'm not as far up as you....but I still take 'em out for Winter. BSTS
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-21-2013, 07:53 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
On the newer trailers the master kill will remove power from everything except the propane detector. I pull my batteries during winter storage otherwise they would be dead by spring.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-21-2013, 08:00 AM   #6
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
I do not pull mine anymore. Instead, I installed a solar battery charger. I checked my Lifeline AGM batteries several times over the winter last year, and never had less than a 13.6 charge.
ID:	196067   Click image for larger version
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 09-22-2013, 07:21 AM   #7
Thanks for your replies but my main question is where is it located. People say it's kind of like a dial that you turn. Anybody got a picture?
Old 09-22-2013, 07:40 AM   #8
Thumbs up
If you can find the converter the switch should be nearby....ours is under the the front couch, the switch is on the right, converter inside.
FWIW....ours does not shut everything down, you will have to install your own "isolation" switch for that option.
ID:	196190   Click image for larger version
PFC
RLC
Old 09-22-2013, 07:46 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
On late models, maybe yours, there is no master kill switch, just the "Use/Store" switch by the door. The "Store" position will leave only the propane detector working. (The trailer tongue jack is direct wired through its own fuse to the batteries.)
Do you have a factory solar system with your AGM batteries? If so you can leave the "Use/Store" in either position and it will keep the batteries up. If no solar, disconnect the batteries for long term storage.
Doug and Cheryl
Old 09-22-2013, 11:30 AM   #10
1988 32' Excella
Robbinsville , New Jersey
From everything I've read Airstreams have a Use/Store switch OR Master Kill switch depending on year built, NOT both, unless another switch was added.
Old 09-22-2013, 11:44 AM   #11
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
The use/store switch is always hot, along with the propane detector, and front jack.
I pull the positive lead off the batteries, and add a dashboard style solar charger @ .85 watts. The constant fog in Morro Bay doesn't help much though.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 09-22-2013, 12:46 PM   #12
2005 19' Safari
GLENDALE , AZ
See details describing the installation of a marine battery isolator switch at this link:
http://www.airforums.com/forums/f449...ml#post1350746
After installing this switch, turning it to OFF will completely disconnect both batteries from your Airstream and eliminate all parasitic drains.
Old 09-23-2013, 01:14 PM   #13
Was to -I think you hot it on the head - you either have a kill switch OR the "in use" / "store" button but not both. I'm in MN and will pull my AGM batteries. I store it inside so the solar won't help. Thank all of you for your remarks. Jack Canavera - I camped at Wagon Wheel Campground in Door County and met you in maybe 2003. Thanks for your great replies to folks, I always enjoy your answers!
Old 09-23-2013, 02:34 PM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
I remember you! I have. picture of your trailer at the campground. Was up there last year in August. Still one of our favorite places to stay.
Jack
Jack Canavera
STL Mo.
AIR #56
