Old 09-23-2013, 07:13 PM   #15
KYAirstream's Avatar
Northeastern , Kentucky
My 79 had the converter wired into a standard light switch to turn it (the converter) on or off. Is disconnecting the converter the same as the master kill switch? There is no other switch that I can find on mine...
KYAirstream is offline   Reply With Quote
Old 09-23-2013, 07:28 PM   #16
1974 Argosy 20
Kooskia , Idaho
A master kill switch is one which disconnects the 12 volt batteries completely from the trailer. Not the same as a switch which turns off the converter/charger.
Old 09-24-2013, 05:24 AM   #17
Skater's Avatar
1995 30' Excella
Bowie , Maryland
A lot of older ones didn't have a master kill switch. If you want one, the easiest thing to do probably is to install one on each battery. Slightly harder but more convenient is to install a master kill switch somewhere in the wiring between the batteries and the loads.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-24-2013, 06:09 AM   #18
Good thought. Was having a brain lapse when I posted though.....all my fuses have been switched out with breakers, including main breakers for the entire 12 volt system, which I suppose in effect accomplishes the same thing as the kill switch.
Old 09-25-2013, 05:31 AM   #19
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Only if you shut them off every time. And keep in mind things like the jack might still be powered.
