Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-26-2004, 06:35 AM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Marker light electrical sealer?
Finally had a warm day to seal/inspect the exterior marker lights on my Airstream. Since the Airstream had sat for twenty years before I got it, some of the marker lights had moss growing under the lenses. I was pleasantly surprised that all the bulbs, and electrical contacts were in amazingly good shape.
It appeared that, after the bulbs were installed, the assembly was sprayed with some sort of clear lacquer before the lense was installed. Does anyone know what the spray was? I am familiar with greasing electrical connectors to prevent corrosion, and have always just used whatever I had laying around.
Since I am currently servicing the turn signals, backup, and marker lights, what do you recommend for "care and feeding" of the electrical contacts?
Tom
Old 01-26-2004, 07:18 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Tom!
This is a guess, but I would suspect that the coating that you are seeing may very well be PlastiCoat. If the bases were installed prior to the final finishing, which I suspect that they may well have been, it would almost be a natural to have PlastiCoat on the exposed surfaces. With the protection afforded by the lenses, the PlastiCoat would likely survive unscathed for many years if that is the coating.
Dr. Jonhnson, an electrical engineer on another list to which I subscribe, recommends dielectric grease on the electrical contacts as well as ground contacts. He also suggests aluminum conductor grease on the ground contacts that touch the skin of the trailer.
I haven't disassembled the lights on my trailer, but I do use the the dielectric grease that Dr. Johnson suggested and it has made changing bulbs much easier.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 01-26-2004, 07:22 AM   #3
LOST , Hawaii
Conformal coating is a clear sealer used on the bottom of printed circuit boards to seal and protect them. I'm not sure in 1967 it would have been very common. Maybe clearcoat or something similar applied by a PO?
Dielectric grease is very good at protecting from corrosion but kind of expensive. OTOH I've seen chassis grease used and it works.
John
74Argosy24MH is offline   Reply With Quote
