Old 06-22-2018, 08:10 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Managing the 70's electrical harness
Everything runs in the ceiling. It is a very difficult area to work in because getting the skin down is impossible without help, and even then it's not pretty. I suggest cutting the skin into manageable segments. This is not beautiful, but it doesn't have to be ugly. And it doesn't significantly affect the longitudinal strength of the skin. The interior skin adds little to the strength of the shell.
In this 23' 1973 Safari I had already cut the ceiling skin at the center vent when I removed and sheeted that vent closed. Now I wanted to remove the 300-ohm TV twin lead and replace it with RG-6 coax. Turns out that with the skin removed, the existing twin-lead could be used to pull the coax for a total replacement. Now I have coax from the bedside up to the control center in the front dome.
First, you remove the A/C cover and the interior hard mount.Then pull the skin down.
Name:	ceiling hanging.jpg
Then cut the skin approximately in the middle of the A/C. The strips on the sides are narrow there. Once cut, reinsert the piece that's still attached.
Sometimes you can find a rib that can provide a convenient place to reattach the two pieces of skin. If not, rivet a tab on the ends of one and then attach the other. You can even make notes that will be hidden under the A/C cover.
Name:	ceiling drain.jpg
Put the A/C cover back in place and the new cut is hardly visible.
Name:	ceiling finished.jpg
By the way, this is the Burning Man trailer, so it doesn't have to be pretty, just functional. On the other hand, I have done this to several other trailers where it had to be pretty and I found that that was fully achievable.
Zep
Old 06-29-2018, 02:56 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If that impossible to see little joint somehow drives you crazy .... fill it with caulk dyed to match the ceiling. I wouldn't bother to do it, but some things can drive you nuts.
Managing email notifications J. Morgan Forum Admin, News and Member Account Info 11 02-04-2015 08:24 AM
Managing Paper & Pics while traveling knunut Full-Timing 2 04-08-2010 10:31 AM
Managing Profile Comments TankerIP Forum Admin, News and Member Account Info 3 01-03-2010 08:27 PM
