Old 03-12-2015, 12:10 PM   #1
2008 23' Safari SE
Columbus , Ohio
main breaker
some times when using a/c or heat pump main breaker kicks off .
using 30 amp from main house connected to 30 amp box 300 feet away.
Dave.hendrix is offline   Reply With Quote
Old 03-12-2015, 12:21 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
300 feet is a long way for a 30 amp circuit. Did it used to work with the AC or is this a new phenomena?
If it used to work fine and this issue is new, then I would suspect that your compressor may be drawing too much power when it fires up. Could be any number of issues that will require a trip to an AC technician.
If this circuit is new and you've never used it successfully before with the AC, then I would suspect that the run may be too long for the wire size and you are getting a lot of power loss. You can have an electrician check the circuit to make sure it capable of providing the rated power.
Bob Martel
WBCCI# 5766
Retainer for Back-fed Branch Breaker used as Main Dean E Electrical - Systems, Generators, Batteries & Solar 2 11-08-2013 12:59 PM
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 08:25 PM
main breaker box Grapes Electrical - Systems, Generators, Batteries & Solar 2 04-05-2013 11:53 AM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 08:37 PM
help with finding main breaker cyberstream Classic Motorhomes 3 08-27-2010 09:01 PM
