Old 10-13-2015, 09:38 PM   #1
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
Magnum inverter install question?
Hello,
This question is directed towards a certain member who would know the answer. But anybody can chime in.
Lew, I'm using a 300a class t fuse on the dc side of my ms-2012 install. That being said you need to incorporate a disconnect before and after the fuse. I was going to use a disconnect for the pre-fused side, but can I use the DCLD pigtail to prevent any flow going to the battery from the inverter? I'm assuming it shuts the inverter down as if you hit the on/off switch, not allowing the charging cycle to initiate. Or do I need to install another disconnect post-fused. Please assure what I'm thinking.... Thank you
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 10-13-2015, 10:34 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by ArtisanAir View Post
Hello,
AA,
The specific cable order should be like this:
• battery
• 2/0 cable up to 5' for the total length to the inverter positive, 4/0 up to 10' (it's in the MS-2012 manual), double 4/0 from 10-15 feet maximum run length
• 300 amp class T inverter fuse
• 300 amp inverter disconnect switch
• final run of appropriately sized welding cable
• positive terminal of the inverter
The only place I would tap off this positive run is at the battery side of the inverter fuse, not at the switch. The cable should be unencumbered from the fuse to the inverter by any other DC loads.
For a feed to the house positive bus bar, I typically use a 50 amp marine circuit breaker and 4 AWG cabling.
*****Remember to place all fuses and circuit breakers within 18" of the positive battery terminal to meet NEC code!
Any more questions?
Old 10-13-2015, 10:44 PM   #3
lewster's Avatar
Here's a bit of a visual. This is from an Interstate coach and uses a Magnum MMS-1012, but you can see the order of the devices. I also use solid copper bar extensively in my installations to keep the wire runs as short as possible since it's pretty tough to get a 2/0 or 4/0 cable less than 3", including lug ends or to make short, sharp bends.
Old 10-14-2015, 05:39 AM   #4
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Your the man! So a disconnect after the 300a fuse is not needed? Also what do you recommend for a bcc or automatic relay switch, or bim. I am worried about the tow vehicle's alternator getting involved with the agm batteries I just installed. I've seen swelling from I assume over charged batteries, also charging different types of batteries from the same source? Certainly the alternator does not have the 3, 4, or 5 stage charge like the inverter. What do you recommend on your installs when charging from your tow vehicle? Thanks again Lew!
Artisan Airstreams
Old 10-14-2015, 06:14 AM   #5
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
One other question I had is, what size copper bar would be a equivalent to 4/0 copper wire? Would 1/4" x 3/4" suffice?
Artisan Airstreams
Old 10-14-2015, 06:45 AM   #6
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Lew, I was looking at your pic in this thread a little harder and I think I'm seeing a isolator seloniod? Is that how it is switching from vehicle alternator charge? Im getting wound up in different applications for charging the system from the tow vehicle.... Im sure there is a simple way or the sophisticated way. Please help
Artisan Airstreams
Old 10-14-2015, 06:49 AM   #7
2006 19' International CCD
Hillsboro , Texas
Schematic
Lew
Do you have some schematics of this configuration? Any schematics for connecting 12 volt DC in a trailer, example: installing an inverter, shunt, etc.
grwalk is offline   Reply With Quote
Old 10-14-2015, 09:26 AM   #8
lewster's Avatar
There IS a disconnect between the inverter fuse and the positive inverter terminal (big red switch marine switch). Interstate vans use a BIM from Precision Circuits, but for trailers, I simply pull the fuse on the charge line of the TV. You don't want a continual 14.2 VDC from the alternator hitting the batteries, as they will never have an opportunity to float and will overcharge. The fuse is easy to identify from your vehicle manual.
Old 10-14-2015, 09:28 AM   #9
lewster's Avatar
Originally Posted by grwalk View Post
Lew
These are easily found from the equipment makers. Magnum has some great wiring diagrams in their manuals....available on-line, as do Blue Sky Energy for solar. AM Solar also has a couple of good block diagrams on their web site.
Old 10-14-2015, 09:29 AM   #10
lewster's Avatar
1/8" X 1". You will never bend 1/4" solid bar.
Old 10-14-2015, 09:30 AM   #11
lewster's Avatar
This pic is from an Interstate van. you are seeing the Precision Circuits BIM solenoid. It was already in place from the factory.
Old 10-14-2015, 12:48 PM   #12
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
So long story short you would not charge the AGM batteries with the TV source? That would be the easy answer. How could you use the TV to supply the 12V DC while being isolated from the camper bank? Solenoid? Transfer Relay? I'm getting overwhelmed in different applications, I would like a simplified system (no bim or bcc).
Artisan Airstreams
Old 10-14-2015, 01:12 PM   #13
Pawcatuck , Connecticut
Hi I have taken out all the electrical in my 1971 land yacht I just want to install new exterior wiring that works from the tow plug...also four outlets and overhead track lights air conditioner ... can you make any suggestions about maybe solar I plan on using the AS as a traveling vintage shop
Betty1971 is offline   Reply With Quote
Old 10-16-2015, 04:06 PM   #14
lewster's Avatar
That IS the easy answer. I remove the charge line fuse in the TV whenever I install Lifelines or Lithiums. But then it really isn't required as these rigs all have substantial solar charging capacity.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
Replace House Batteries (Magnum Inverter) MILATV Sprinter and B-van Forum 24 11-04-2014 06:11 PM
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 03:26 AM
Magnum Inverter upgrades Support Admin Airstream Classifieds 0 09-23-2013 12:28 PM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 10:11 PM
