Old 01-04-2016, 05:45 AM   #15
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
All done!
Well here it is... I made the coffin box on the street side in front of the wheel well, 16" x 16" x 72". Those dimensions work great for storing batteries and an inverter. It also doubles as a full size bed. I will install another piece of ply on top of the cover with a piano hinge. When folded out, it will be the width of a full size bed. I made the box out of 1 5/8 metal studs and 1/2 plywood.
For the service, I went with 50 amp. I mounted the shore power twist-and-lock hookup in the back bumper and ran 6/3 romex to the box. I am using a Magnum inverter 2012 2000 watt pure sine wave, recommended by some great support (thanks Lew!). I understand now why he is so adamant about these systems. I will never install anything other than Magnum brand in my trailers. I also partnered it with a Magnum battery monitoring system, DC shunt, 300 amp fuse, and the control panel. I used the Blue Sea disconnect switch ,transfer switch, and DC fuse panel. The transfer switch is for when (if ever) you would like to only run off of the TV power and not the bank. It will switch between the bank and the TV power, they are never married due to different battery charging rates. For the batteries I went with six 6 volt 220 Amp Hour AGM Trojan batteries. They are ran in a parallel series to equal out to 12 volts @ 660 AH. The inverter has adequate spacing above it because I used lexan between the inverter and the mounted accessories, raised off of the inverter. I used 1/8" x 1" copper bar for the run between the batteries and the inverter all bent and shrink wrapped. I installed the AC breaker box and DC fuse box on the exterior of the box for easy access.
I hope you enjoyed following this build!
ID:	255066   Click image for larger version
ID:	255068   Click image for larger version
ID:	255070   Click image for larger version
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 01-04-2016, 01:34 PM   #16
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Where are you people ordering your copper bar from?
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 01-04-2016, 02:27 PM   #17
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
I ordered it from amazon
Here's a link
http://www.amazon.com/gp/product/B00...ilpage_o05_s00
If you go to "see all product family" you can select different widths, lengths, and thicknesses.
Artisan Airstreams
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
Replace House Batteries (Magnum Inverter) MILATV Sprinter and B-van Forum 24 11-04-2014 06:11 PM
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 03:26 AM
Magnum Inverter upgrades Support Admin Airstream Classifieds 0 09-23-2013 12:28 PM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 10:11 PM
