Old 10-21-2013, 08:29 PM   #1
2014 23' Flying Cloud
Salt Lake City , Utah
LPG generator
Our 2014 23 ft flying cloud has a LPG external port in the front but on the non door side. Is this to be used for a LPG generator? It seems to be on the wrong side for anything else.
J Brinton is offline   Reply With Quote
Old 10-21-2013, 09:02 PM   #2
1974 Argosy 20
Kooskia , Idaho
It is just there for any LP appliance you want, generally a BBQ grill for most people. A longer hose than AS supplies will allow you to use gas wherever you want around the rig.
Old 10-21-2013, 11:02 PM   #3
2017 27' International
Fall City , Washington
AS supplied an LP hose? I didn't receive one with my 28 Flying Cloud.
2017 27FB International
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 10-22-2013, 04:09 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Be advised, this port is low pressure propane, that is downstream from the regulator. If you hook a gill to this port you want a grill without a regulator, just a gas valve. Some grill manufacturers sell this as an accessory; most gas grills are built for high pressure propane.
Also, this port does work fine for my new Yamaha 2kw generator.
Larry
lsbrodsky is offline   Reply With Quote
