Old 11-26-2006, 05:12 PM   #15
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Try this
Go to the Airstream site (airstream.com) and click on Products and then Customer Services, and them Maintenance Books. They may not have your year, but the most recent manual for your trailer type should have wiring diagrams. A little hard to read, but here is little change year to year except between different configurations such as FB vs RB. The diagrams for my trailer date back with minor changes to the introduction of the wide body in the 90s.
John W. Irwin
WBCCI #9632
Old 11-26-2006, 06:58 PM   #16
Silversub's Avatar
2007 25' Safari SS SE
Havana , Florida
Thanks for the suggestion to go to airstream. I emailed their tech people to see if they knew where the fuse was located. Also, thanks for the furnace power lead idea. That is close by and not a difficult connection. I'll keep everyone posted on what Airstream technical provides. Silversub
USNA 68
Beth & Lance
Silversub is offline   Reply With Quote
Old 11-27-2006, 12:54 PM   #17
Silversub's Avatar
Havana , Florida
Airstream Tech responded that the fuse is under the front sofa near the battery. I will check out the box. The radio memory and the LP detector are wired to be always on. Thanks to all. Silversub
USNA 68
Beth & Lance
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
