Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-22-2002, 05:48 PM   #1
kellyw
Profile:
Post Low Voltage Problem
I have a 1974 Soverign 31' airstream. How do I go about troubleshooting a 12V low voltage problem? With the trailer connected to commercial power, a fully charged battery will completely discharge over night. The 110V circuits still work okay. I do not own a maintenance manual for this trailer. Any suggestions are greatly appreciated.
kellyw is offline   Reply With Quote
Old 10-22-2002, 05:52 PM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
do you hear any humming from the univolt unit when you plug the trailer in?
john
Old 10-22-2002, 10:29 PM   #3
FrankR
Profile:
Discharged battery
To determine if a battery is being discharged, first the battery must be checked to determine battery condition. A battery is fully charged when the voltage is measured with a digital volt meter and the voltage is 12.6 or 12.7 volts. If a battery is 12.0 volts the battery is 75% discharged.
An easy way to determine what 12volt circuit is using power is to remove all fuses from their holders. Before removing fuses, note their position as to amps. Indivually replace one fuse at a time and note any sparking as fuse is installed. Nope the 12 volts will not shock or harm any human. If no sparks are noticed. check battery and disconnect the ground cable untill some 12-15 hours have passed. Then again check battery voltage. If possible make all the checks with the 120 volt ac not connected. NO shore power. Depending on results of tests, more checking maybe required.
Name:	ford rewire.jpg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 10-23-2002, 06:35 PM   #4
kellyw
Profile:
Smile
To john hd: I did not notice any humming from the univolt unit when you plug the trailer in.
To FrankR: Thanks for your help. I suspect my problem may be in circuit#4. How can I find out what area of the trailer is serviced by circuit#4? The reason I suspect this circuit is because the ohms reading across the positive and negative battery connectors (with the battery disconnected) is close to a short until I pull out the fuse for circuit#4. I will try what you suggested, however it will be awhile before I get back down to the trailer to check it out.
Thanks for the help,
kellyw
12v problem Chuck Electrical - Systems, Generators, Batteries & Solar 18 10-08-2003 11:15 AM
electrical problem kent osborn 1966 - 1968 Safari 3 09-27-2003 05:30 AM
Voltage Regulator Rayk Airstream Motorhome Forums 2 09-16-2003 06:36 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
