Old 02-14-2015, 10:27 PM   #1
Miami , Florida
Loud noise from converter
Hi everyone,
I have friends in town with their newish (2013?) Safari and they are preparing for a 2 week side trip. When they plugged the trailer into AC power (using an adapter from 30 amp to a standard 3 prong plug) a new, loud noise started coming from under their refrigerator, where their converter resides. The noise is clearly louder than the hum that usually comes when the converter is working. I've checked other threads and came upon a post about loose components on the circuit board. The advice there was that it will only get worse and that the component or entire board should be replaced. Since they are hoping to hit the road on Monday (it is Saturday night now), I am wondering if others agree with the circuit board problem or if you might have other ideas. As it is the noise is so loud and irritating that they would have trouble sleeping in the trailer. Thoughts?
Patricia720 is offline   Reply With Quote
Old 02-14-2015, 11:13 PM   #2
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Loud noises near the refrigerator are sometimes caused by the refrigerator fan:
Refrig fan noise FIXED... really
SilverGate is offline   Reply With Quote
Old 02-14-2015, 11:35 PM   #3
Miami , Florida
Yes, but the refrigerator fan in their unit is above the refrigerator and the noise, sadly is below...
Old 02-15-2015, 02:22 AM   #4
2005 19' Safari
GLENDALE , AZ
The converter also has a cooling fan inside the unit. If their batteries are not fully charged, and they are using a lot of 12-volt lights, etc., the cooling fan could be running (normally, it's off in cool weather and when there's no significant 12-volt load).
Also, there could be some debris or loose wires that are blocking or rubbing on the fan blades.
Does it sound like fan noise? Can you describe what is heard?
Also, there are cooling vents and removable covers in that area. You might be able to take a flashlight and look around inside to locate the source of the noise.
CAUTION: The converter contains 120 VAC inside; use appropriate caution to avoid electrocution. For example, don't go poking around with a screwdriver, wire coat hanger, or even your finger. If you do any poking, use a wooden or plastic stick, ruler, etc., or a drinking straw, or other non-conductive probe.
Old 02-15-2015, 02:40 AM   #5
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Good advice so far, and maybe a vacuum, plastic nozzle, could be used to remove some debris which is hitting the fan. If the noise is a vibration, careful inspection, pushing on stuff with a non conductive stick may find the source. It may be simply something like a wire vibrating against sheet metal or other resonating part.
The important thing to remember is be very cautious.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 02-15-2015, 09:40 AM   #6
Miami , Florida
Excellent suggestions! We will proceed as you suggest.
Old 02-15-2015, 10:21 AM   #7
Trailer's Avatar
2015 25' FB Flying Cloud
Palm Springs , California
We are getting factory replacement for our converter that sounds like a '57 Volkswagen
Trailer is offline   Reply With Quote
Old 02-15-2015, 10:29 AM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sounds like the fan within the converter. I wonder if the bearings on the fan have gone bad? I'm not sure how the fan works on this vintage trailer, but mine is temperature activated. So when you first plug the trailer into shore power, the converter is pretty much silent. Only after a significant 12 volt power draw, or warm inside temps does it come on.
If it's coming on as soon as shore power plugs in, I'd look at the fridge fan first. It would be pretty easy to diagnose by keeping the fridge off when plugging into shore power.
Jack
Jack Canavera
STL Mo.
AIR #56
Propane heater works but started having loud noise when it first starts GeGe Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-04-2014 03:28 PM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
High idle, or maybe stuck throttle and hugely loud revving noise at start. PuffinPotter Classic Motorhomes 33 08-08-2011 11:47 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
more than 4 lights = loud converter Astroboy Batteries, Univolts, Converters & Inverters 5 08-04-2009 09:01 PM
