I just plugged in my 85 Excella for the first time. A very loud buzzer went off inside the trailer. I could see the overhead light was on, but I unplugged it until I can figure out what is going on. The batteries are properly connected and I'm plugging it into a 20 amp outlet in the house. I don't need the microwave or AC. The 30 amp plug coming out of the back of the trailer is plugged into a converter, then into the same extension cord both the PO and Holiday Trailer in Albuquerque used. Everything worked perfectly with no deafening and scarey buzzing sound.
1994 34' Excella
1978 31' Sovereign
Mansfield
, Georgia
I have a 1994 34' Excella and have not encountered the buzzing you described. The only thing I can think of is that a previous owner direct wired a smoke alarm, that the back-up battery is dead, yet when you plug in to power, it activates the alarm to let you know the battery needs replacement. I would suggest you plug in and letting it buzz while you search the interior of the trailer to identify the source.
