Old 08-05-2013, 11:12 AM   #1
pawnguy's Avatar
2005 30' Safari
Joplin , Missouri
Looks like a burnt spot
Hello I was camping this weekend and when as i was unplugging our power cord I noticed it had a black burnt spot on one of the terminals on the plug in cord end (see photo to follow) Any idea what that could be caused from. Thanks
Mark
A Real Pawnguy... "when life gives you lemons, make lemonade"
pawnguy is offline   Reply With Quote
Old 08-05-2013, 11:19 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Often that's caused by heavy current demand when the connection inside the socket is less than ideal.
— David
Old 08-05-2013, 11:37 AM   #3
pawnguy's Avatar
2005 30' Safari
Joplin , Missouri
What should I do about but. Here's the photo.
Old 08-05-2013, 11:39 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, poor [loose] connection with a moderate to heavy load. I never like a receptacle that can hardly hold my cord while plugged in. If the 30 Amp receptacle is broken or too loose, I can use my 50 dog bone on a lesser used tighter fitting receptacle. Two other choices is to have the bad receptacle replaced. [I had that done once] Or to change sights.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-05-2013, 11:43 AM   #5
Salem , Oregon
Images: 18
Hi, your picture shows the trailer end of your cord. When you connected it did you make that twist before you tightened the nut? Make sure that the trailer receptacle is clean and replace the cable end or complete cable. [I would just replace the end] Hopefully the trailer connection isn't burnt or damaged.
2005 Safari 25-B
Old 08-05-2013, 01:05 PM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
You could carry a small spray can of contact cleaner and use it before making electrical connections to make sure there is no insulating dirt in the connection.
Old 08-05-2013, 01:17 PM   #7
pawnguy's Avatar
2005 30' Safari
Joplin , Missouri
Thanks everyone for the input. So at this point I should replace connector end and check trailer side for damage and use cleaner from here on out?
Old 08-05-2013, 04:13 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-05-2013, 06:36 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Also a good idea to make sure the circuit breaker is turned off before connecting or disconnecting the cord.
Old 08-20-2013, 11:55 AM   #10
pawnguy's Avatar
2005 30' Safari
Joplin , Missouri
Thanks again for all the assistance. Bought a new plug/cord and camped all weekend and the plug looked great afterwards. Thanks again and God Bless.
Purchase the Camping Spot Intrepid Full-Timing 10 07-16-2012 11:37 AM
tight spot assistance Los Angeles bgipeair Towing, Tow Vehicles & Hitches 1 02-14-2012 09:44 AM
Rock & Roll Hall Of Fame Camping Spot? jambie On The Road... 1 07-25-2011 12:08 PM
Atwood water heater burnt wire richinny Water Heaters, Filters & Pumps 5 06-21-2011 07:27 AM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
