Old 01-14-2007, 10:24 AM   #1
acton
little lightbulb on top of breaker box
Anyone know where I can get it? Its for a 63 tradewind, screw in type little bulb.
durans54 is offline   Reply With Quote
Old 01-14-2007, 10:48 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Light bulb
Hi, I can't see your bulb. But, if its like the one on my 67 safari you can pick one up at the local home-hardware store. Mine looks like a Christmas light bulb. There are different base sizes so bring it with you.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-14-2007, 11:00 AM   #3
1960 24' Tradewind
santa barbara , California
I too need one for my 60 trdwnd ,i had removed it and now it has kinda
vanished (happens at my house) so anyone know the watts or the size?
Thanks ,
Scott
scottanlily is offline   Reply With Quote
Old 01-14-2007, 11:10 AM   #4
1967 22' Safari
1960 Caravel
Images: 8
Thanks ,
Scott
Is this the one your looking for?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-14-2007, 11:23 AM   #5
acton
Thanks guys!
Old 01-14-2007, 12:10 PM   #6
1960 24' Tradewind
that looks like it ! any bulb number to reference or watts? Im just wanting to
get the right one .
Thanks for the pic
Scott
Old 01-14-2007, 12:26 PM   #7
1967 22' Safari
1960 Caravel
Images: 8
get the right one .
Thanks for the pic
Scott
This is a guess since I'm not looking at the bulb or setup. The bulb is a C7 12v
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-14-2007, 12:27 PM   #8
1960 24' Tradewind
thanks ,I appreciate that info .
Scott
Old 01-14-2007, 12:55 PM   #9
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
I'm guessing my 1960TW came to me with the original bulb. It is not a C7 type. You can find a pic (albeit not real clear) in this link from another thread:
http://www.airforums.com/forum...1&d=1166987894
The bulb didn't work so I removed it and have looked several places to find a replacement without any luck. The bulb got crushed in my bag, but I still have the base. Looks like a candelabra base like a C7. I tried a C7 bulb, but it didn't light either. I got the info off the bulb before it broke. It says GE (as in General Electric) NE-45. If anyone finds a source or finds a C7 works in theirs, I'd like to know too.
I just found this on the web GE NE-45 Neon Glow.
This is exactly like what was on my breaker box.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 01-14-2007, 03:25 PM   #10
1967 22' Safari
1960 Caravel
Images: 8
Thanks for the Photo link Sugarfoot, That has to be a 120v light. Not like the light in the 67, It's 12v. Good Luck
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-15-2007, 07:50 PM   #11
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
Replacement found
Yes you're right, it is a 120V bulb. I did a little searching and found a cheap import replacement bulb with glass housing (they also sell a plastic variety). Bulbconnection.com has them for 2.50 each. Bulb B7A replaces the NE-45. Donsbulbs.com has 8 new old stock bulbs made in the USA for 16.00 each but you have to buy 3 to make his $40 minimum order. I'll see how the cheap one works first.
Aluminocentricity
Old 01-25-2007, 08:40 PM   #12
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
Is it SUPPOSED to light up?
Got the bulb and tried it today. Guess what, plug in the trailer and it doesn't light. Then I remembered seeing something the original PO wrote in his notes. I'd read it a long time ago and it didn't make sense. Top line of card, it looks like "Plug in electric - light bed off." Could he have meant "light BULB off?" The box with the light IS UNDER the bed.
Name:	F60TW Original Owner's Notes.jpg
When I was looking for this little bulb I read something about use as an indicator light and in Hickok tube testers. Also something about the brightness was directly proportional to the current levels. Is it possible this bulb on the breaker box was an indicator of incorrect polarity or an electrical short? I'm as far from an electrical wizard as one could get. Don't tell me my ORIGINAL TO TRAILER bulb really did work, especially since I accidently broke it.
Aluminocentricity
Old 01-25-2007, 08:53 PM   #13
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
YES the old bulb could have been good. The bulb only comes on if the polarity is reversed or wrong . If it not on all things are good. It is a 120 volt light bulb. Hope this helps.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 01-25-2007, 09:03 PM   #14
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
aHA!
Yes, Andrew, THANKS! You've solved the mystery, for me at least.
Aluminocentricity
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
Doctor Box Pahaska Our Community 7 11-18-2002 08:53 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
