Old 01-25-2007, 09:49 PM   #15
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Although it seems like a strange concept, you never want to see this bulb working. I've broken one of these myself. Thanks for doing the research SugarFoot.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-25-2007, 11:24 PM   #16
1960 24' Tradewind
santa barbara , California
Andrew ,also a thanks as well ,I myself was wondering if the bulb had another purpose other than just turning on with the power .I had power anyway
yet no light ,normal .I have a small round hole drilled in the rear bath cabinet
that the PO drilled there to look thru to see the bulb .Hmmm ,he must have been concerned about it .Well ,Ive found no electrical problems at all with
any fixture or recepticle since Ived had this coach so I don't know what the PO had in mind there.
Scott
scottanlily is offline   Reply With Quote
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
Doctor Box Pahaska Our Community 7 11-18-2002 08:53 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
