Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-26-2006, 08:41 PM   #1
shinybean
shinybean's Avatar
Profile:  Greenville , South Carolina
Question Lights go on & off ???
Okay, I had something a little strange happen today. I was working in my AS with the AC power connected. I had been working for about 2 or 3 hours, when all of the lights inside turned off by themselves. Then they came back on, but started turning off and back on about every 15-20 seconds. Each time they turned off and back on, I heard a clicking sound coming from the voltage converter area. I just purchased the trailer (my first), and it does have a battery connected, but it is dead. Has anyone ever had this problem? Thanks!
shinybean is offline   Reply With Quote
Old 11-26-2006, 09:57 PM   #2
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
Shineybean,
What you have is a circuit breaker in the circuit, and, instead of burning up a lot of fuses, it is cycling on and off; much like a flasher does on your turn signals on your TV.
Actually, since it took a while to happen, I would be prone to looking for a light or outlet that has too much resistance, thereby causing the breaker to trip after the resistance caused enough heat to up the amperage used. It is actually possible that the only problem
is a loose conection.
Good luck,
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 11-26-2006, 10:32 PM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Good reply, in addition - how much current are you using? Heavy tools? Many lights? Is there an overload where the breaker is tripping normally as it is designed, or might it be a defective breaker?
There may be a variety of causes, and you may get other replies with more ideas. Good luck with it.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-26-2006, 11:42 PM   #4
klattu
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 854
Oh cool!
You have a ghost!
klattu is offline   Reply With Quote
Old 11-27-2006, 07:05 AM   #5
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
With a dead battery and ALL the lights on in the trailer the convertor is being asked to do too much and blowing the circuit breaker. Convertors are battery charger and not designed to run sustained loads without a battery in the circuit as the main current source. Install a battery and have it charged before you attempt to have such a load on the convertor.
If you don't want to install a battery now consider using houeshold, 110 volt, light during you work.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 11-27-2006, 06:47 PM   #6
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
I had an occassional problem in my 73 Sovereign. About 3am the middle ceiling light would turn itself on. My battery would also seem to mysteriously go dead without warning and then come back to life. Even more mysterious this appeared to be related to the light above the sink/stove area. Rather than a forest gremlin it appears to be related to a faulty rocker switch on the sink/stove light. I have not yet replaced the switch but diconnected it and have not yet have repeat problems.
Lumatic is online now   Reply With Quote
Old 11-27-2006, 09:45 PM   #7
shinybean
shinybean's Avatar
Thanks for the tips so far. As soon as I get a chance, I'll check those things out. To answer some of the questions:
> I had all of the interior lights on. (Those small little bulbs are just so darn dim, I need all of them on to even get a little light in there...)
> I did not have the heat or air running. I assume the fridge was running though. (Original fridge, and I did not have gas connected to the trailer).
> I did run the shop vac for a couple of minutes at a time here and there.
> I also had a work light (garage type, hang-up light with a cage around a 75 watt bulb) turned on most of the time.
Does the household 110V light use less power than the interior lights? The bulbs that I have in my AS are the #1141 automotive light bulbs. (I have a 1969 25' Tradewind) It just doesn't seem like these would consume enough power to make this happen. But, like I said, I'm still learning...
Thanks again for the tips!
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 07:39 AM
Night Lights KY Girl Our Community 1 11-10-2002 03:08 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Blinking Galley Lights 1985air345 Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
