Old 04-11-2016, 06:18 PM   #1
Climber's Avatar
2012 27' Flying Cloud
Portland , Oregon
Lights flicker when water pump runs
All of a sudden my LED ceiling lights start to flicker whenever the water pump runs. The pump is also noisier than usual. Any one else have this problem, or have an opinion as to the cause? My batteries check in at 12.5 v or 75% charged. No blown fuses or other issues. I'm a bit perplexed...
Thanks!
Climber
2012 27' Flying Cloud FB (Bella)
2014 F-150 3.5L Ecoboost
Climber is offline   Reply With Quote
Old 04-11-2016, 06:57 PM   #2
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
I have the same problem with my new classic, particularly with the under cabinet galley lights. The water pump also sputters somewhat. I was told by my dealer that it wasn't an issue. I'm not convinced!
Sjcjr is offline   Reply With Quote
Old 04-11-2016, 07:10 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
You have a resistance in that circuit. The pump draws enough current to cause the resistance to lower the voltage to the lights. Trace the circuits back to where the lights and the pump connect; between that point and the battery is your issue.
Old 04-12-2016, 01:56 PM   #4
Climber's Avatar
Portland , Oregon
Thanks for the advice. I'll look into that.
Old 04-13-2016, 05:38 PM   #5
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Water Pump circuit
On my 2015 19' FC the water pump is on the 12 volt DC circuit #5 Blue wire 15A fuse. Also on that circuit is the Closet light and compartment light.
If the pump commutator/brushes on the water pump's motor were getting worn or defective they could cause the motor to not run smoothly and to pulse the current draw on that circuit.
Another possibility is that the vibration of the motor is affecting a loose connection on that circuit.
One way to determine if it is just vibration would be to take the motor's two wires, disconnect them and wire them directly up to a battery (either the ones in the trailer or bring in one and set it on the floor. Before disconnecting any wires, make a drawing of the wires and mark each wire to make sure that you put it back correctly and that you know which wire is the motor plus and minus to connect up to the battery in the right manner.
BoscoMN is offline   Reply With Quote
Old 04-13-2016, 06:17 PM   #6
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
Flickering Lights
Have a 2016 27 FC Led lights flicker on occasions even without nothing running not sure whats causing any ideas?
mcomeaux is offline   Reply With Quote
Old 10-25-2017, 08:57 AM   #7
2017 27' Flying Cloud
Fort Worth , Texas
Any solution found? I have a brand new FC 27FB and the bathroom lights flicker when the water pump runs.
billrector is offline   Reply With Quote
Ceiling lights flicker, tail lights are dim Zeitlupe 2011 - 2015 International 11 07-01-2016 07:29 AM
Lights flicker kathy149 General Interior Topics 3 01-31-2014 01:47 PM
Lights dim and flicker tinman9 Lights - Interior & Exterior 1 11-18-2013 08:40 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Water pump runs but no water comes out goswick Water Heaters, Filters & Pumps 18 07-05-2009 06:10 PM
