Old 05-27-2006, 05:35 AM   #1
Didgiman's Avatar
1968 20' Globetrotter
Phoenix , Maryland
lights and fuses
I am trying to get my exterior lights functioning for inspection. The back-up, flashers, turn signal, and brake work, but not a single one of the "running lights" the surround my 68 Globetrotter (like the three on the front over the Airstream plate) lights up. Is there a fuse box like exists on a car. If there is I can't find the bugger. Any advice otherwise. Can't go camping for nothing but the these silly little lights-Driving me crazy.
Didgiman is offline   Reply With Quote
Old 05-27-2006, 06:41 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
don't let the lights make you crazy...
they are not fused, the wiring runs from a junction under the front of the trailer directly to each light.
inspect each of the lights, look for corroded ground connections under the body of the lamp. usually a new bulb and new fasteners that securely ground the lamp will fix the problem.
most folks do not try to fix the lamps since they are less than 5 bucks each. replacements are available at most napa or truck/farm stores. the fixtures are made by a company called "grote".
good luck, and do not forget to seal the holes through the skin if you replace the lamps!
john
you call them ferrets, i call them weasels.
no brake lights libbysmom Airstream Motorhome Forums 5 05-22-2006 08:34 PM
Running Lights blowing fuses neil.ervin Electrical - Systems, Generators, Batteries & Solar 11 04-30-2006 07:37 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Astrodokk on the road-tail lights out PeterH-Airstreamer Airstream Motorhome Forums 10 12-02-2003 07:35 AM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
