05-29-2006, 12:35 PM
1978 31' Excella 500
Palm Bay
Lighting up the Marker and tail lights for show
Many of us have converted our exterior lights to LED's. I did the clearance lights but haven't found the 4X4 inch LED's for the tail lights. I want to be able to turn the exterior lights on when parked and unhooked from the TV. Here is a diagram of how I did it. Since I am not an electrician, I would like some input on my solution. Is there anything wrong with it? It seems too simple. It works but I haven't hooked the TV up with this configuration.
What I did was to purchase a two position rocker switch that lights up when engaged. It has 3 poles labeled GROUND, LOAD and POWER.
I ran POWER from the 12volt fuse board line from the battery 1 to the switch, ran the LOAD to the green wire connection on the fuse board for the clearance/tail lights and ran the GROUND to a screw on the aluminum interior wall.
I am assuming that with the switch off, I haven't changed anything as far as the 7 wire connector from the tow vehicle.
Any thoughts or cautions would be appreciated.
05-29-2006, 12:48 PM
1966 22' Safari
1979 30' Argosy
Armada
, Michigan
There is nothing wrong or odd about the way you powered your running lights. I just tested my turn signals using a 12 volt accessory source, hooked into the wiring harness underneath. So, no, nothing wrong, just make sure you have a 15 amp or whatever your drawing, fuse inline to prevent a fire in case of a short.
05-29-2006, 06:03 PM
Palm Bay
John,
Thanks for your reassurance. I appreciate it.
05-29-2006, 06:23 PM
1998 31' Excella 1000
South Berwick
, Maine
I took a 10 amp auto spade type fuse and stuck it between the two side by side connections at the twelve o'clock position on the 7 way plug. The fuse fits perfect. Works like a charm - simple, isn't it? (12:00 being keyed position on the plug; just so happens mine is straight up)
WBCCI 24291
New England Unit
Metropolitan NY Unit
05-31-2006, 07:57 PM
1976 25' Caravanner
Campton
, New Hampshire
That is slick
05-31-2006, 09:22 PM
2020 30' Flying Cloud
1995 25' Excella
Clear Lake
Without thinking about it first...
Do you do this only off of battery power, or do you do this either off battery and plugged in?
Mark
72 Sovereign: L couch, mid-twin, rear-bath "When you come to a fork in the road, take it" "It was impossible to get a conversation going; everybody was talking too much." "If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
05-31-2006, 09:51 PM
Contributing Member
Austin (Hays County)
Use a flasher
Buy a TV-end connector and a replacement flasher. Wire the flasher between the terminals at the 12 position of the connector. Just plug the trailer into it and the position lights will flash. With the addition of a switch, you can choose flash or steady.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
05-31-2006, 10:42 PM
2012 31' Classic
Golden Valley
06-01-2006, 03:30 AM
South Berwick
, Maine
Makes no difference. A '72 would not use the flat spade type connectors unless the plug was replaced to match modern tow vehicle. A '72 would have used the round style pins and the terminals for the running lights are most likely in a different position.
WBCCI 24291
New England Unit
06-01-2006, 06:36 AM
1995 25' Excella
Clear Lake
You are very correct that at the trailer plug itself, I can't accomplish this trick. I was assuming that I would leave the tow umbilical connected to the trailer and put the fuse in the tow vehicle end of the umbilical, which has been rewired to a 7 pin to fit my tow vehicle.
Mark
