Old 03-26-2005, 12:12 PM   #1
Lighting problem
Hello:
The 12V interior lights in my 72' OverLander are very dim. I have replaced the battery with a new DieHard deep cycle RV battery. I have checked all fuses within and connected to the Uni-Volt V. Still dim lights.
When connected to the tow vehicle with iginition on, the lights are bright.
It seems that my battery is not being charged (through the Uni-Volt) when connected to shore power or when being towed.
Any help would be appreciated. I would like to salvage/repair the uni-volt if possible.
rcloyd
rcloyd is offline   Reply With Quote
Old 03-26-2005, 12:30 PM   #2
till's Avatar
Lisle , Illinois
Images: 108
Have you checked the voltage on the battery while your pluged in to shore power?? The voltage you get while pluged in will tell you how your Uni-volt is doing. Any cheep meter form Radio Shack or Harbor Frieght will work. I think you chould be getting some where around 13 to 14 volts when pluged in and some where around 12.5 to 12.8 volts when not pluged into anything.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 03-26-2005, 12:38 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by rcloyd
Hello:
rcloyd
I have the same issue with mine. Battery runs down rather quickly. I put a battery tender for the short term fix.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-01-2005, 01:22 PM   #4
Thanks for the responses. I checked the battery voltage when plugged/unplugged to shore power. Voltage was 12.77V in both cases.
Does this mean something is wrong with the uni-volt?
rcloyd
Old 04-01-2005, 01:31 PM   #5
Sounds like a flaky Uni-Volt.
I replaced mine with an InteliPower 60 amp unit. Works great now.
You can find the best price for an InteliPower at www.bestconverter.com
The site is run by a fellow forum member and he offers a discount for other forum members.
I had the same exact problems that you have. The Uni-Voly was old and tired.
Do you hear any "humming" coming from it? Loud humming, (or a buzzing sound) is a strong indication that it is dying.
Anon is offline   Reply With Quote
Old 04-01-2005, 02:59 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
With the ignition on, the lights will be brighter because they are being supplied around 13.5 vdc since the alternator is running.
If your battery is not taking a charge when connected to shore power or when being towed, there is a problem with the wiring or battery connections. Either should charge the battery.
The Univolt can not be ruled bad until you stick a meter on it's output. Exact numbers escape me, but the Univolt should be registering around 13 vdc output when it is on.
There is a distinct possibility that you have a wiring problem (most likely dirty connections) that a modern day charger will not solve. More detail about the Univolt can be found on my webpage (link in my signature). But feel free to contact me offline if you want numbing detail.
Tom
Old 04-01-2005, 04:25 PM   #7
TomW's Avatar
1967 26' Overlander
Loud humming means the Univolt is under load whether it be from lights & fans running, or a bad internal component. Make sure all lights & fans are off before deciding if the hum is too loud.
Tom
Old 04-01-2005, 10:04 PM   #8
Tom
Thanks, Tom.
Yeah, that too.
I left out that important detail. Don't be running a lot of stuff on 12VDC when you want to test my theory.
My transformer hum was LOUD and CONSTANT. No matter what load was on it.
I know from working with industrial 480VAC transformers that they will "hum" when under a load.
I am a firm believer that if it is electrical and it is over a certain age then it is better to replace it than it is to play with it.
An electrical problem is no fun. I do not like the old Uni-Volt systems as there are much more reliable systems out there. They weigh less, take up a lot less space and do more.
I cannot tell you the amount of care that my Dad put into pampering his 1973 from the day it was new. He even ran a 30 amp line out to where we parked it, mounted it an official post even. We would remove the battery if we were going to park the trailer for more than a two month period. The Uni-Volt would gas the battery in no time.
All I can honestly say, is that there are two systems on the trailer that I will not rebuild anything for: electrical and LPG.
Old 04-03-2005, 12:04 PM   #9
87MH's Avatar
1978 31' Sovereign
Images: 292
The 12V interior lights in my 72' OverLander are very dim. I have replaced the battery with a new DieHard deep cycle RV battery. I have checked all fuses within and connected to the Uni-Volt V. When connected to the tow vehicle with iginition on, the lights are bright. It seems that my battery is not being charged (through the Uni-Volt) when connected to shore power or when being towed. Any help would be appreciated.....
rcloyd:
One of the things I found when "doing" the '78 Sovereign was corossion at the electrical terminals on the fuse block....it may be that battery connection to the main fuse block is compromised, while the charge line from the TV is making a good connection....
It does not take much surface corossion to impede amperage.
I would suggest accessing your terminal block, and remove, clean, and retighten each compression terminal, one at a time, and also check the connections at the battery and battery connector areas.
Luck...please let the Forum know what you find.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
