Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-24-2005, 01:24 PM   #1
RiskIt
RiskIt's Avatar
Profile:  1972 25' Tradewind
Lake Worth , Florida
Light switch
Does anyone know where I can find the switches (3-way??) used on my 72 A/S overhead lights...?? The ones that are used with the vents. I broke one and the one in the bathroom (same type) only works some off the time. I've tried RadioShack and places like that but I guess the stuff is too old. Thanks for any help.
RiskIt is offline   Reply With Quote
Old 07-24-2005, 01:41 PM   #2
Jim W
Jim W's Avatar
Profile:
I bought mine at Inland RV about two years ago.
http://www.inlandrv.com/
SF CA area
77/31' Airstream
99/Suburban/454/4.10
#18248
Jim W is offline   Reply With Quote
Old 07-24-2005, 01:50 PM   #3
BURNZEE
Profile:
That's were I got mine as well.
FYI
They have a brass color on the shaft and nut. I looked at four places for silver/alum finish, but couldn't find any and went with the brass.
BURNZEE is offline   Reply With Quote
Old 07-24-2005, 03:58 PM   #4
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
The kicker is the shaft length
Originally Posted by BURNZEE
That's were I got mine as well...
Me "three".
FWIW, I looked pretty hard both around here, and online. The switch's OEM does not appear to support the shaft length anymore.
Tom
Old 07-24-2005, 06:57 PM   #5
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
got one from my local A/S dealer. then bought another at Lowes. turned out to be too short, but it works.
the other day, I saw a box of switches at a local small hardware store, and whadya know? they had one that appears to be the right thing. so I picked it up.
you know those slide-out drawers of various and sundry hardware fasteners and doo-hickies? it was in one of those.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-25-2005, 12:17 PM   #6
RiskIt
RiskIt's Avatar
Just ordered them from InLand ($16.50ea.). I've bought alot of stuff from them. Someone said something about the shaft size. Not sure if this helps but on mine (ones that came from A/S) you can adjust the lenth that hangs out. They have two little nut's and they use them to look the switch in place. You can adjust how much sticks out using the nut's.
I had replaced my light covers and I couldn't get them to work. I stil am having problems with the crank handles not being able to reach the crank shaft. I used longer screws to hold the handle/light cover in place but it doesn't grab the shaft so you can't open the vents. It looks like the light covers are different enough to make it not work. Anyone have a fix on this...? I got one vent/light working OK, but the other two I can't crank the vents up or down becuse of this.
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 07:31 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 09:55 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 05:05 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 12:03 PM
test
