Old 08-18-2004, 10:00 AM   #1
light switch
I stumbled across something odd in my "new" airstream yesterday. I noticed when I turn off the light switch above the mid bed it turns off all three overhead light in home, the radio installed in front overhead cabinet and fan in living ceiling. What do you make of that? Did Airstream do this or a previous owner, any ideas?
Also, does anyone know where I can get my removable radio looked at? I know the speakers work because they buzz when I turn the radio on, but I can't get any radio stations to tune in. In fact, I can't even get static.
Name:	Radio under Console.jpg
ID:	8404   Click image for larger version
Name:	Above Mid Bed Fixtures and Switches.jpg
happier is offline   Reply With Quote
Old 08-18-2004, 10:56 AM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
Kill switch sounds like a great idea for us forgetful folks. Does the radio have an antennea?
Over59 is offline   Reply With Quote
Old 08-18-2004, 03:10 PM   #3
radio
Yes, I do have an antenna on the hitch/curb side. Do you have any idea how I could check to see if it is connected without taking off any panels? The radio can be removed just like old car radios you use to install yourself (would slide into a slot), but I don't have anywhere to test it, any ideas?
Old 08-19-2004, 08:06 PM   #4
TSandersParis's Avatar
1972 29' Ambassador
Sumner , Texas
You can go ahead and remove the radio from the trailer. Take it to a location where you can get good reception (radio reception is not too good inside a metal trailer) and 12VDC. Then insert a bare copper wire into the antenna connection. You should begin to pickup some radio stations if the radio is functioning. If you get no broadcast signal then something is wrong with your radio. Another option is to take it to a automobile and try to connect the radio cable to it. The radio antenna is easy to reach on some of the older vehicles.
Good luck!
Tom
TSandersParis is offline   Reply With Quote
Old 08-19-2004, 08:10 PM   #5
radio
The power supply to the radio is part of the bracket that it plugs into along with the antenna and speaker connections. There are only holes in the back of the actual radio when I remove it.
Burned 4 way light switch Ferroequine Electrical - Systems, Generators, Batteries & Solar 1 08-06-2004 09:56 AM
need light switch John Greenlee Electrical - Systems, Generators, Batteries & Solar 2 03-26-2004 10:27 PM
Interior Light Switch danesh General Interior Topics 3 12-08-2003 06:37 PM
Parts source for four position light switch overlander76 Electrical - Systems, Generators, Batteries & Solar 6 11-16-2003 08:24 PM
Light Switch JOECAR 1975-1976 Excella 500 1 03-16-2003 08:30 PM
