Old 01-16-2004, 10:23 AM   #1
Light Fixture Covers (plastic)
Hello all:
Haveing recently purchased a 29 foot 1975 Ambassador, I am in the process of cleaning up and replacing pats of the enterior.
Question: does anyone make or have the plastic light fixture lens's for the light fixtures in an AirStream. Mine are yellow with heat and age and would not block as much light if they were replaced with new lens.
Vic
ke4lkq is offline   Reply With Quote
Old 01-16-2004, 10:30 AM   #2
light fixtures
Andy From Inland RV has them, I recently replaced all three of mine. Good Price, and it really shed in a lot more light. BTW, I would just make a list of everything you need to replace and make one order, it saves on postage.
Repodog is offline   Reply With Quote
Old 01-16-2004, 11:06 AM   #3
LIGHT FIXTURES
Thanks for the info... I'll look on the web for the site if there is one. Maybe you have phone number or web link for Andy??
Vic
Old 01-16-2004, 11:12 AM   #4
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
201154 Is the Airstream part number this can be purchased from any Airstream dealer. Give them the part number and they can have it sent to you as well.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 01-16-2004, 06:28 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Andy at Inland RV has a sale going through March. At the above website you can match the vintage of your trailer to a photo before you order. Scroll down until you get part numbers in the 65XXX range for Ceiling Light Lenses.
If your window and compartment door (battery, fridge) gaskets are cracked, dry or crusty take note in the 45XXX area. And your 2 Vent Pipe Gaskets (#45701) may allow leakage too. Just trying to help you control water leakage and prevent floor rot... Do searches on some of the above key words if you want more info (window gasket, vent pipe gasket).
5 meter Langford Nahanni
